Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-18-2004, 07:50 PM
acidburn20016 acidburn20016 is offline
Turbos
hey i just wanted some input on what turbo system would be the best for my 98 type r teg. and i am thinking about sellin and gettin a 97 gsr teg so what would be the best for that also.
Old 08-18-2004, 08:30 PM
crx91's Avatar
crx91 crx91 is offline
Re: Turbos
why would you sell your type r. you cant move forward if you take a step back. im not sayin the gsr isnt good allready, im sayin that your at a good star all ready.maybe greddy or turbonetics t3/t4 turbo.get a full kit and dont run more than 6 psi.you should be atmost 210 whp.if tuned prop.
Old 09-07-2004, 10:35 PM
b20crxsc b20crxsc is offline
Re: Turbos
if you want your turbo to be more efficiant you will drop the compresstion down to like 9:1, the gs-r allready has a lower compression than the type-r, so i say sell the type-R you'll end up with more hp in the long run, i also suggest iron cylender sleeves they resist more heat
Old 09-10-2004, 02:19 PM
00EclipseGTsport's Avatar
00EclipseGTsport 00EclipseGTsport is offline
Send a message via MSN to 00EclipseGTsport
Re: Turbos
Get a used LS Integra with a 5-Speed trans. Swap in a light flywheel, and race clutch. Drop the engine in. Install a cylinder brace, block girdle and quality head gasket. Then slap on a Drag turbo kit and be done with it.
Should the LS engine go, you can pick another up cheap and swap the turbo on it.
~ Steve
00 Eclipse GT - 00 Montero XLS 4x4 - 96 Integra LS
99 Kawasaki ZRX 1100 - 81 Suzuki 450 cafe' racer - 75 Kawasaki KX 250 - 74 Suzuki YZ 125
69 Ford Galaxie XL Conv. - 69 Ford LTD 2-door Formal Top - 67 Ford Galaxie 500 Conv.
CHECK OUT MY RIDES BY CLICKING HERE
Old 09-12-2004, 05:48 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Re: Turbos
2 good kits are the f-max (turbonetics) and rev hard kits.
