Go Back   Automotive Forums Car Chat > Buick > Grand National/GNX
Old 08-18-2004, 06:51 PM
Loudz34 Loudz34 is offline
Angry 87 Gn turbo ~ Problem
Hey everyone, I have an 87 Sn 3.8 turbo~ Its running funny~ I have a Maf too low code~ when the car warms up and you put it in gear it will fall flat on its face... I tap the maf and it will go from 6kg to 22 to 255 to 3, stall stumble... I believe this is the problem... but at idle it seems as if its running on 4 cylinders~ can it also be in the ecu~ coil pack or ing module? thanks... Greg
Old 08-19-2004, 03:00 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Bad MAF sensor, If you have the money I would suggest a LS1 MAF and a translator. Berter metering of the fuel= better performance/fuel economy. As for the coil pak, yea it could be a sign but, with your MAF bad your car relies on the calpak to keep it running (Real rich fuel maps.) You could of fouled some plugs. I would reccomend getting your MAF situation figured out before you do anything. a bad MAF will make these cars do alll sorts of goofy crap.
Welcome to AF. Always nice to see a GN owner
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 08-23-2004, 07:21 PM
Re: 87 Gn turbo ~ Problem
thanks soo much, This is for a friends Gn, I have an 87 Gnx.... I stumbled upon this board.... thank god....
Old 10-21-2004, 09:02 PM
Buick_GN Buick_GN is offline
wow
Where did you get your hands on a GNX? How much did it cost?
Old 12-07-2004, 01:02 PM
vicious6's Avatar
vicious6 vicious6 is offline
Certainly the mass air flow. If you have troble locating one you may try www.kirbanperformance.com
1986 Buick T-Type
1987 Buick Turbo T
1987 Buick Century Limited (My Faithful Driver)
