Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 08-18-2004, 06:29 PM
Sally2Trees Sally2Trees is offline
Help removing water pump 1990 325
I am trying to remove a water pump from a 1990 325 and i dont understand how the timing belt tensioner moves to get out of the way of the water pump. There is spring behind it with a pin thru which appears to compress in order to release tension. but the tensioner feels like it is "fixed" instead of "tensioned". The manual says to use "proper tool" to compress spring. Any help would be appreciated.
Old 08-18-2004, 08:53 PM
jeffreyb4me jeffreyb4me is offline
Re: Help removing water pump 1990 325
Do NOT loosen the tensioner bolts ! ! The tensioner is 'fixed by it's mounting bolts, the spring is ONLY there to pre-tension the belt @ new installation time, used belts MUST NOT be 're-tensioned' ! !
now, you need to grab the end of that pin and pull it away from the waterpump as far as you can [ compressing the spring completely ]. The pin will be moving towards the alternator. Now for the fun part...while your holding the pin with one hand, you need to 'lock' it with the other [ not much room ].....I recommend using 2 small needle nose 'vise-grip's, they work very well for me. Note that the "proper" factory tool was only a small block with a thumb screw that fit over the pin and lock it. BMW left up to you to figure out how to pull on the pin and the 'tool' took up most of the end of the pin. I haven't seen mine in 20 years but haven't missed it.
hope this helps and best to you.......................................jeff b.
Old 08-19-2004, 02:16 PM
Thanks, I got it out and new one in in reatively little time ~3 hours.
