Old 02-05-2002, 01:03 PM
kidrocket kidrocket is offline
Send a message via AIM to kidrocket
money burning a hole in my pocket
ive got a little over 600 to spend. I was thinking about the skunk2 intake manifold, but id like to know what mods in this price range would see the highest gains. Id like to stay away from NOS at the time. your info is appreciated
Old 02-05-2002, 01:25 PM
soul180's Avatar
soul180 soul180 is offline
do you have an exhaust yet?
UGSTYLES
Old 02-05-2002, 03:44 PM
no exhaust yet but im buying my friends comptech thats only been on his car for like 3 months. i left that out. ill have about 600 after i buy that
Old 02-05-2002, 05:52 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Cams!
http://www.crower.com/pdf/76.pdf
Old 02-05-2002, 07:36 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Ill second that!
Bang for buck you cant beat cams!!! :flash:
Old 02-05-2002, 09:04 PM
nittanys1's Avatar
nittanys1 nittanys1 is offline
Send a message via AIM to nittanys1
Can you get cams for an automatic? And what exactly are they and what do they do, thanks.
Old 02-05-2002, 11:05 PM
praxis praxis is offline
Don't waste your money on an intake manifold if you are not going to be adding all the other necessary components to get the most from the modification...throttle body, port matching (at the minimum), more fuel and spark (because the air that the new intake is taking in, is not going to burn by itself).
I would like to know more of what you have and your future plans, before I would recommend what you should spend your money on. Does your car need regular maintenance? Are there any 'needs' on the vehicle? What kind of racing are you going to be doing?
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 02-05-2002, 11:47 PM
i just had 60000 mile maintenance, tire rotation, and alignment so it should be good on needs for a while. its my daily driver so i cant go too crazy with it. I just plan on stoplight racing with some track time on weekends.
also what cams are available for under 600. keep in mind that i need install green too. i can do some stuff but i wouldnt try to tackle that one. i did the intake, header and short shifter on my own though
Create Weep Holes on Doors? buickultra2000 Park Avenue 3 05-15-2010 12:10 PM
Burning oil at idle bhw33191 Caprice 20 09-13-2009 02:43 PM
Burn Hole In Drivers Seat! Trahan360 Cars in General 1 06-14-2005 02:11 AM
