Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 08-18-2004, 07:07 PM
LPcatcher01 LPcatcher01 is offline
Send a message via AIM to LPcatcher01
Tail lights problem
Today my mom told me my tail lights weren't working, none of them. So i pulled one out and found out that they actually do work, but they are just not bright at all. So i was wondering if anyone knew what this could be. Any help is appreciated, Thanks, Phil.
Old 08-18-2004, 09:32 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: Tail lights problem
It's probably a bad ground. The ground wire for the tail lights is attached to the frame somewhere under the passenger side quarter panel and can be a nightmare to get at. Instead of disassembling the entire rear body I pulled off my rear bumper cover and cut about 1/2 inch of insulation off the tail light ground wire (It's black and thicker then the other wires) and soldered another wire to it. I connected the other end to the frame with a sheet metal screw. Instead of soldering you could also use a tap splice (also called a suitcase connector) to tap into the ground.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
