Old 08-18-2004, 05:01 PM
AmatureCDV Driver AmatureCDV Driver is offline
Send a message via AIM to AmatureCDV Driver
water pump again.
ok, so i am trying to get the lower timing cover off. there arent anymore bolts to take off, but i cant get it out. it wont make it over and under and around all the pulleys and what not. any help is greatly appreciated!!!!!!!!!!!!!!
desprate jon
Old 08-18-2004, 07:31 PM
crank pulley
ok, so i found out that you have to remove the crankshaft pully to remove the timing cover, but how do you keep the pulley from moving while you are turning the bolt. I dont have air tools so this is a little more difficult. Any help is apprediated. Thanks.
Jon
Old 08-19-2004, 04:53 AM
butch100 butch100 is offline
What year 'scort are you working on?? 1.9 or 1.8 Ltr.??
if it's a 1.9 you have to remove 2 small bolts on the far
side of the oil pan to remove the flywheel access cover.
then you need to wedge a large screwdriver in the flywheel
teeth to keep it from turning ,then you can remove the belt.
You will also need to remove the upper left hand side motor
mount to get the cover off. Some have said they got their's
off without removeing the mount but it must have been a
wrestling match to do so. Remember to support the motor
with a jack while the mount is off. I just used the sissors jack
that comes with the car and a peice of wood to avoid damageing
the oil pan and was good to go.
Old 08-19-2004, 09:06 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: water pump again.
on my 2.0 I managed to muscle out/in my timing belt cover. If your car is a stick shift, put it in gear with or without the parking brake on. Then you don't need to block the flywheel.
