Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 08-18-2004, 01:01 PM
sweet944 sweet944 is offline
Lowering Ride Height
I have a 1987 - 944 & just put some sweet 17" rims on..
I looks great, but it sits a little high..
does anyone know if I can lower the ride height without changing the suspension?
Old 08-18-2004, 03:25 PM
83-944 83-944 is offline
Re: Lowering Ride Height
only in the rear, unless you go ghetto and cut/heat the springs.
83 - Porsche 944 - daily driver
62 - VW Karmann Ghia - never ending restoration project
95 - Ford Mustang - wifes
Old 08-19-2004, 10:49 AM
xveganxcowboyx xveganxcowboyx is offline
Lower profile tires.
Old 10-01-2004, 12:38 PM
I have low profile tires...
What I mean is the distance from the top tire to the wheel well.
I want the tires/wheels to be up into the wells....
Old 10-02-2004, 07:41 AM
neo the hacker neo the hacker is offline
adjust the rear torsion bar, i think 83-944 as the pics
Old 10-03-2004, 06:04 AM
got your pic right here:
For the front, you'll probably have to change out the springs though.
Old 10-03-2004, 09:21 AM
Thanks.. 83-944... The info is very helpfull. I will be turning some wrenches this week.. I 'll let you know how it works out....
Also, the front looks higher than the rear so I am going to look into some springs & struts... It's getting to be time to replace the struts anyway... More money, more money, more money....
Old 10-03-2004, 06:05 PM
I know koni do a insert for the front, instead of replacing the full leg you cut the top off the old one and take out all the guts then drill a 14mm hole thru the bottom then put in the insert and bolt it down, cool. 9m told me at the weekend and said there at a good price as well.
Old 04-29-2005, 08:35 PM
mccormicwe mccormicwe is offline
Send a message via AIM to mccormicwe
I know you didnt want to do a total swap but if you get full koni susp. then it will lower ur car and those 17s will look sweet. I did that with my '87 944 and i love it it is sexy as hell. I put a set of koni yellows with 17 in boxster wheels and yokohama tyres. im sure u will be happy with the setup
