Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 08-18-2004, 12:30 PM
mrmadara mrmadara is offline
Dead trunk release on 01LS
First of all, I'm so glad to have found this forum - you folks have alot of information that my 'knowledgeable' dealer has neglected to mention or been unable to explain (i.e. hollow front-end noise when I hit a bump). Thanks!
Anyone had problems with their trunk release not working? I have a 2001LS - 55K. At first, only the cabin button was failing (remote buttons still worked for several days) - but now, none work and I have to open manually with a key. The trunk release doesn't appear to be regulated by a fuse as far as I can tell, but not sure.
Any thoughts/advice is greatly appreciated.
mrmadara - BRAND new user. =)
Old 08-18-2004, 12:57 PM
Quik_LS's Avatar
Quik_LS Quik_LS is offline
Send a message via MSN to Quik_LS
the most common problem is that you accidently turned on the Truck-Release - lock out. It's a little button near the trunk latch (middle - lower part of the trunk opening, just inside the rear lip) when you were putting something in the trunk.
Quik LS - Austin, TX
more, more, more.....
#0018 ESP SCCA solo2
LLSOC.com - President
see my mean LS
see my Lotus Esprit - Quiker
Old 08-19-2004, 07:43 AM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: Dead trunk release on 01LS
Due to the gradual failure, it sounds like a bad solenoid to me.
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 08-20-2004, 06:14 PM
I'll check for the latch, but the remote buttons have been working today (go figure) - so if gradual/intermittent failures = bad solenoid, that looks like my problem.
You guys rock - thanks!
