Old 08-18-2004, 12:12 PM
golfdude316 golfdude316 is offline
Question Audio - Kicker
I just bought an alpine mrd m500. I need to know if it will drive 2 dual 2ohm L5 solo barics?
Old 08-18-2004, 12:16 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: Audio - Kicker
whats the RMS on the amp and speakers??
also make sure when you hook them up, you do it in a way that doesnt go below the amps impedance ie..1ohm
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 08-18-2004, 12:31 PM
Re: Audio - Kicker
600 on subs and 500 on amp
Old 08-18-2004, 12:36 PM
Question
can I go below 2 ohms with the amp or will it burn it up? It says its 2 ohm stable so I dont want to push it!
Old 08-19-2004, 01:12 AM
ptown201 ptown201 is offline
Re: Audio - Kicker
It's really not recommended, the amp will probably go into protection and turn itself off. If it doesn't actually turn off, it will heat up and may eventually cause it to burn out.
Old 08-19-2004, 02:58 PM
simple_country_guy's Avatar
simple_country_guy simple_country_guy is offline
Send a message via Yahoo to simple_country_guy
Ok .. the real ? is.....
If your amp says that it is 2 ohm stable you should be able to pound on it at 2 ohms for as long as you want. As with any amp if it is in a confined area and doesn't have fresh air then it will get hot and shut down. Running it at 2 ohms will cause it to heat up quicker but if you have good air to the amp you will have no problem. Now the fun part is going to be wiring them so your amp will see 2 ohms. You will need to run your each sub in series and them parrallel them at the amp. This will essentially give you two 4 ohm subs that when connected to your amp will parrallel down to 2 ohms. If you not certain how to do that then let me know and I will sketch something out to e-mail you.
Sure, I know how to do that......
Old 08-19-2004, 03:17 PM
Even better...
Here is a link on how to wire your subs. You want to use option #2.
