Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 08-18-2004, 12:31 PM
djhoppa djhoppa is offline
Unhappy 1989 Bronco II wont turn over HELP!!!
Won't Start
1989 Bronco II wouldnt turn over, but would crank. Put gas in car, and it started, with slight hesitation. The next day, car started in the morning, but during my break, would not start. battery seemed a little drained while trying to start, with no more cranking from the starter, only one click. This happened 2 months ago, but Triple A came, put gas in the car, played with the battery terminal a bit, and the car started fine. Please help! is this a starter issue, an alternator issue, or a battery issue?
Im not a car person, what should i do next? please help!
Old 08-18-2004, 12:42 PM
Tractor 68 Boy's Avatar
Tractor 68 Boy Tractor 68 Boy is offline
Send a message via AIM to Tractor 68 Boy Send a message via MSN to Tractor 68 Boy Send a message via Yahoo to Tractor 68 Boy
Re: 1989 Bronco II wont turn over HELP!!!
Sounds like a starter to me, you might want to check you battery leads also though, make sure they are tightly connected to the battery and starter. Have your battery tested as well and have a current flow and alternator test done at the same time.
1988 Cadillac Deville: 4.5 V8, auto, front wheel drive. White exterior, white leather interior.
1979 Ford F250: 351C/M V8, 4speed manual transmission w/granny gear, 4X4, standard cab, long bed. Blue exterior, blue interior.
1968 Ford Mustang Coupe: 200 I6, 3speed auto(C4), red exterior, red interior. (Future drag race/project car.) (Mods include 632 BBF V8, C6, 10 point roll cage, 5.34 spool rear, tubbed, tube frame, custom interior.)
If you cant beat em, buy one. GIT ER DUN!!!!!!!
Old 08-18-2004, 01:05 PM
thanks for the advice... its really strange though, because this happened before and the car was completely normal for a long time... i hope this is only a battery issue! if not, any idea of the cost for this repair?
Old 08-18-2004, 01:22 PM
Starters are not cheap, yours will run you at least $130 (non-remanufactured, get a new one), batteries can run about $120 (if you get a good one) alternators can be $160 (also get a new, non-remanufactured) battery cables can be about $60 for both. $400 for all of those + labor= $700-$1200. Clean the terminals on the battery first, tighten the cables at the battery and starter and ground connections. Then if still nothing gets better, get it all tested. The tests will run about $60-$80. But if the test fails you will have to spend some money to get the part that failed replaced. Good Luck and if you need any more help let me know.
