Old 08-18-2004, 11:16 AM
BikerTrash BikerTrash is offline
Question Electrical Problem Where do I start?
OK, I'll explain this as well as I can, the jeep runs like crap when you first start it, if you let it warm up a little it starts running better, but if you turn on anything electrical in the jeep it runs like crap and wants to die, even putting on the brakes, headlights, air conditioner or anything, I dont even know where to start, it was doing this just when I turned on the head lights, so I replaced the switch, and it has been getting worse and worse, the battery is good, the alternator is good. it has been getting alot worse, use to I could drive it about 2-3 miles and it would clear up and not have any problems at all till the next day when I started it cold again. someone please give me something to check or somewhere to start. thanks
Old 08-18-2004, 11:22 AM
Tractor 68 Boy's Avatar
Tractor 68 Boy Tractor 68 Boy is offline
Send a message via AIM to Tractor 68 Boy Send a message via MSN to Tractor 68 Boy Send a message via Yahoo to Tractor 68 Boy
Re: Electrical Problem Where do I start?
Sounds like you should have it scanned by a dealer. I am not being a smart ass but that is one of the easiest and fastest ways to find the problem.
1988 Cadillac Deville: 4.5 V8, auto, front wheel drive. White exterior, white leather interior.
1979 Ford F250: 351C/M V8, 4speed manual transmission w/granny gear, 4X4, standard cab, long bed. Blue exterior, blue interior.
1968 Ford Mustang Coupe: 200 I6, 3speed auto(C4), red exterior, red interior. (Future drag race/project car.) (Mods include 632 BBF V8, C6, 10 point roll cage, 5.34 spool rear, tubbed, tube frame, custom interior.)
If you cant beat em, buy one. GIT ER DUN!!!!!!!
Old 08-18-2004, 11:48 AM
Dale Aeppli Dale Aeppli is offline
HI, FIRST OFF WHAT YEAR, MAKE, MODEL ,ENGINE DO YOU HAVE
DALE [email protected]
Old 08-30-2004, 08:39 AM
IT is a 1990 2 door cherokee with a 4.0.....
Old 08-30-2004, 02:47 PM
gtmud gtmud is offline
With your engine running, put a digital meter across your battery terminals. DON'T REMOVE YOUR TERMINALS WHILE ENGINE IS RUNNING!) Should read 14 +/- 2 volts. Turn on the headlights, see what happens to your voltage, does it drop out? It really sounds like your alternator is going, enough power to run the engine and thats all. Keep in mind, everything in your Jeep is controled by electrical current. Any charging problems will affect your running condition.
Old 09-01-2004, 08:22 AM
I'll try that, but I have gauges in the dash, and my amp guage never moves, it stays between 13-14 volts regardless of what is on
Old 09-01-2004, 09:54 AM
glennco1 glennco1 is offline
Measure your voltage at the battery before you start your rig as well, this will give you an idea of how good your battery is.
You may want to watch the voltage drop when someone starts your Jeep as well. This will tell you how well your battery is handling excessive load.
If the battery is starting to go bad, this will cause your alternator to work too hard and can lead to premature failure.
I agree with gtmud though, I think this is an alternator issue.
Old 09-03-2004, 08:40 AM
OK, GUYS, youve sold me, I am going to pull the alternator off and take it for testing, I think we have a shop here that will do test if for free, and that will be as good a place as any to start. it does get worse the more electrical stuff you turn on, such as the fan for the A/C it runs steadily worse the higher you turn the fan until it will finally die,
sucks I have a 4 1/2 inch lift with brand new 33/12.50's to put on it, but wanted to get this fixed first, thanks alot and let you all know what happens.
in the mean time if anyone else has any ideas, please shoot, I'll try anything
Old 09-07-2004, 09:17 AM
OK, took the alternator for testing, and it tested just fine, man what a pain to get to that thing,
still doing exactly the same thing, any other suggestions?
Old 09-08-2004, 12:36 AM
IdahoJeeper's Avatar
IdahoJeeper IdahoJeeper is offline
I'm no genious when it comes to auto mechanics, but I am an electrician. What GT and the others are looking at is the fact that as you continue to load down the system, more draw is being put on the alternator than it can handle. The guage on your dash is most likely a VOLT meter, rather than an AMP meter.
Perhaps your local shop could actually measure the amp draw on the alternator and see what it's trying to crank out. There may be some hidden load out there, a short, maybe, too small to blow a fuse but big enough to drag on the system. Then you do what an electrician would do...start disconnecting stuff (pull fuses, relays) until the problem disappears.
HAPPY HUNTING!
You like jazz, she likes Klingon opera, so you compromise - you listen to Klingon opera...
You like Cherokees, she likes Grand Cherokees, so you compromise - you buy a Grand Cherokee...
