Old 08-18-2004, 09:13 AM
TireGaint TireGaint is offline
Help: The Best Way/safest Way To Drain Out Paint From Spray Can?
Can I invert the spray can and release all the gas first?? THanks.
Old 08-18-2004, 10:45 AM
freakray freakray is offline
AF Modelrater
Re: Help: The Best Way/safest Way To Drain Out Paint From Spray Can?
I don't recommend that method myself, although it may very well work fine.
There is a tutorial on BriansModelCars.com in the tutorials section which outlines my preferred method.
AF User Guidelines
Old 08-18-2004, 10:59 AM
Re: Re: Help: The Best Way/safest Way To Drain Out Paint From Spray Can?
Thanks Ray. I need to make by own pink primer for my ferraris. Will it explode?
Old 08-18-2004, 11:29 AM
AF Modelrater
Re: Re: Re: Help: The Best Way/safest Way To Drain Out Paint From Spray Can?
I don't actually know to be honest, although I would say I don't think it would.
They tell you to turn the can upside down and spray to clean the nozzle, I don't think they'd tell you to do something that would be dangerous.
The tricky part is, once you've got all the propellant out the can, how do you get the paint out?
You can't drill a hole as that would be unsafe.
AF User Guidelines
Old 08-18-2004, 11:55 AM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
The few times I've wanted to do this, I've only wanted small amounts of paint for touch-ups, etc. All I do is grab a pop bottle lid and tilt it about 45 degrees, then tilt the can a little bit and spray away. There's a little overspray (so don't do it over your mom's favourite artpiece) but 99% of the paint goes into the lid. If you wanted to drain the entire can, I would probably just spray it into a pop bottle (clean and dry, of course), then transfer it into whatever container you want to put it into. In fact, a pop bottle might just make a good storage container!
I work slowly!
Old 08-18-2004, 01:40 PM
Just brought 2 can of Tamiya Large White primers and X-7 to make the pink primer....I inverted the spray can already, and try to release most of the gas in next two days, and then drill the bottom, to get the paint out...Hope it goes smoothly, no explosion. hahaha will see
Old 08-19-2004, 07:01 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
I've read people getting paint from automotive cans by simply spraying into a jar/container, then pouring into a airbrush as they had more control over an airbrush than a spray can.
Seeing that you want to achieve this with Tamiya spray, it should theoretically easier, as Tamiya's paint is a lot thinner.
Good luck, let us know how you get on.
Old 08-19-2004, 07:26 AM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
i always just take a large funnel (sometimes i make one out of paper or cardboard), put that in the top of what ever container i want to store the paint in, then spray till i have how much i want.
For best results, heat the can as you would if you were going to paint the car and shake very well.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 08-19-2004, 07:57 AM
CADguy's Avatar
CADguy CADguy is offline
To get paint out of a Tamiya can get a drinking straw, and place that over the nozzle, then just simply spray the paint through the straw into the new jar. Easy as pie, and no overspray..
Matt
Old 08-19-2004, 08:27 AM
Vric's Avatar
Vric Vric is offline
here is how to do it:
http://www.briansmodelcars.com/tutor...ID=3&CurPage=1
Old 08-19-2004, 10:43 AM
Martbee Martbee is offline
Originally Posted by Vric
Dooh, Vric, you had me a inch behind you !!!
Exactely what I was searching for but you beat me !! The ideal ressource to drain the paint... and it work well.
Old 08-19-2004, 01:26 PM
Oh I just finished spraying pink primer on the F50. I chose to direct spray into a pop can, which was in warm water bath. After the primer was in the pop can, I used a metal rod to stir continously until no more gas bubbles coming out. First experience is good, and saves a lot of primer by using airbrush. Thanks for all of your replies. Thanks again.
Old 08-19-2004, 03:46 PM
Murray Kish Murray Kish is offline
Getting Old...
The link Vric posted is the way I do it now. However, I HAVE done it the other way too (let the pressure out and drill hole in can) and I wouldn't recommend it. If you somehow convince yourself to do it that way, here's some things to think about:
- make absolutely sure that the nozzle is depressed for a long time. When the pressure is released, it cools the temp of the can/paint down. Then as the can slowly increases back to room temp, guess what, it builds back up some pressure. I rigged up a little device that held the nozzle down overnight to be sure all the pressure was out.
- watch out for clogs/plugs. It happens. You might think the pressure is out, but it's not. No good way to be sure of this, so you're on your own...
Or, here's a better suggestion. Do it the way shown in the link on Vric's message. Much easier, and less risky...
Murray
Old 08-19-2004, 05:35 PM
bvia's Avatar
bvia bvia is offline
I ended up creating a nozzle just for this (for Tamiya cans) using ally tubing and superglue.
I use empty small glass jars (usually Model Master) to decant into. I first cover the top of the jar with plain old duck tape (yup..duck, not duct!) and then cut an "X" into the tape that will just allow the nozzle to fit into the jar and a triangle at the edge of the inside jar lid (to allow the gases to escape) and decant away!
hth,
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 08-20-2004, 09:10 PM
Hi Bill, do you have pics of your special nozzle?
