Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-18-2004, 08:01 AM
jeter75 jeter75 is offline
Send a message via MSN to jeter75 Send a message via Yahoo to jeter75
HELP PLEASE....Desparate !!!
Ok...My husband rebuilt his engine....put all back together, and now there is no fire to to spark plugs, coil, or anything. He had to leave for Active Duty, and I really need to get this truck back running. Have someone that can look at it, if I only knew what to tell them to look for. That's where I need your help.
Dodge Ram 1500 1/2 Ton 318
Hopefully someone can tell me something very simple, ( not to mention inexpensive)....to check...Have exalted all efforts!.......Please tell me there is a Dodge "God" out there that has the solution. Thanks in advance !!!!!
Old 08-18-2004, 05:28 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Re: HELP PLEASE....Desparate !!!
I'm guessing it turns over. If there's no spark, then something is wrong with the electrical system somewhere. That could be in the coil, distributor, wiring, or the computer. It could be something simple and inexpensive, or something complicated and very expensive. Sorry I can't be of any other help, but without having the truck right in front of me there is no way for me to know what exactly it is doing when it's cranked over.
Old 08-20-2004, 01:37 PM
Sport45 Sport45 is offline
Re: Re: HELP PLEASE....Desparate !!!
Are there any AF members in Lubbock that could go by and take a look at it? Let's help out our active duty guys (and gals) when they need it. I'd go if I was closer. It looks like it's a 1994 model by the way.
Old 08-20-2004, 02:16 PM
Re: Re: Re: HELP PLEASE....Desparate !!!
Sport45......I just want to say a huge heartfelt "Thank-You" !!!!!! Whether there is anyone nearby or not that can help, the thought means more than you'll ever know. Thank you so much !!!
Old 08-20-2004, 05:04 PM
LTJGWorth's Avatar
Yea I would definatly take a look at it if i were closer.
Old 08-21-2004, 02:54 PM
Kickin' it back to the top. Anyone near Lubbock?
Old 08-22-2004, 09:02 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Check all fuses, the ones under the hood and the ones in the in-cab fuse panel. I bet one is blown or has fallen out somehow, or something.
Yeah, does it even turn over, or just nothing?
My Mopars
Old 08-22-2004, 09:12 PM
We have checked all fuses......And also checked the ASD Relay......everything seems to be right. Yes it does turn over just fine......just no fire to get it started.
Old 08-22-2004, 09:17 PM
BleedDodge's Avatar
Well this motor was just rebuilt right? Even something like a messed with crank position sensor or a throttle position sensor that's out of whack won't let the motor start up.
You probably have power to everything, but one of the sensors won't let it start up. Your best bet would be to take it in and have it diagnosed and everything checked. There might be a number of problems here.
My Mopars
Old 08-23-2004, 07:47 PM
bacchus_00 bacchus_00 is offline
hummm , take the crank position sensor to " discount auto parts" (auto zone, etc) , the test is free ...
Old 08-23-2004, 11:39 PM
that wasn't it......we put a brand new one in.....but we did find the problem......There was one little ground wire..that was not grounded........geesh.....now onto the next problem....there is oil in the passenger side of the motor but not the driver side.......explain that one ?.....I am beginning to think that it is not meant to be......
Old 08-26-2004, 10:25 AM
I don't understand, what do you mean when you say there is oil on one side but not the other? How can you tell?
Old 08-26-2004, 10:31 AM
you take the valve covers off.....there is oil in the passenger side, ( and it is pumping like it supposed to), but there is no oil at all in the drivers side.
Old 08-27-2004, 09:14 AM
bawana bawana is offline
clogged oil passage in block?? check to make sure gallery plugs not missing or leaking under intake in valley.pull dist and gear drive and get pump primer drive shaft and run pump with drill might get crap to come out.put flush in oil and then change oil after and before running.Did motor have a lot of crap in it before it was rebuilt?passages might have to be rodded or blown out.
