Old 08-18-2004, 03:57 AM
hmooblis hmooblis is offline
newbe ?
sorry but is their a differnece in tire/car balanceing and alinement? how long does it take to get it done at a shop and price?
Old 08-18-2004, 04:24 AM
Re: newbe ?
anyone? please help
Old 08-18-2004, 04:31 AM
taranaki's Avatar
taranaki taranaki is offline
Banned
Re: newbe ?
If you could perhaps paraphrase your question into English,and let us know what part of the world you live in, we might be able to help.
Are you asking the difference between wheel balancing and wheel alignment by chance?
Old 08-18-2004, 05:10 AM
-Davo's Avatar
-Davo -Davo is offline
Banned
Re: Re: newbe ?
Are you asking the difference between wheel balancing and wheelalignment by chance?
I think he's asking what the weathers like
It's a bit cold...It's raining for the first time in 18 years....and yeah.
Old 08-18-2004, 08:28 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: newbe ?
Well Dave, looks like today is going to be partly cloudy,with a high of 88 and a low of 66. Humidity is at about 73% with a dew point of 63, and the current temperature is 72 degrees.
That's here in Arkansas, let check out your weather there in Sydney.
Lets see, mostly sunny, high of 50 and a low of 49. Humidity is at 88% with a dew point of 48, and the current tempertaure is 52 degrees.
Thanks Dave, now back to you!
Old 08-18-2004, 08:52 AM
Hyatus Hyatus is offline
Banned
Re: newbe ?
In the Washinton D.C. Metro area right now were currently at 69
Todays high will be 85 with a low of 69
With a chance of thunderstorms later in the afternoon.
Humidity is currently at 80% with a dew point of 67.
Old 08-18-2004, 08:59 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Wheel Balancing- There is a light spot in your tire. The wheel is bolted to a machine and spun, the machine then tells the user what wheel weight to knock on, and where to put it.
Wheel Alignment- The camber, toe in/out and castor is all adjusted to even out the wear on all tires.
They both pretty much are ways of avoiding uneven wear on your tires.
When I was working in the tire bay at a mechanics a little while back, the Wheel balancing was just done when the tires were changed, and the Wheel alignment was a 5 min- 1 day depending on how bad the wheel alignment was.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 08-18-2004, 09:06 AM
Mannheim 80 Mannheim 80 is offline
Re: newbe ?
Don't know where you live but tire balancing run $5-10/tire depending where you get it done at.
Wheel/car alignment (setting the car tires at the correct canter/pitch)$35 plus depending on car for front end (Some cars require a rear alignment but usually only needed if you like to curb hop alot.
