Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 08-18-2004, 12:24 AM
ManicMR2 ManicMR2 is offline
Question Tranny grind between 1st and 2nd
My MR2 grinds between 1st and 2nd if i shift pass 2500rpms going into second, if i shift before 2500 rpms it wont grind, just got the tranny flushed, but it didnt help, does anyone know what i could do to correct the problem.
Old 08-18-2004, 01:06 AM
drazhartd drazhartd is offline
Well amigo, it sounds like we have yet another victim to the poor 91/92 syncros.
First, try to find some GM SYNCROMESH (also called Pennzoil syncromesh) and do a tranny flush with that.
Drive it around for a week or so, you should feel a little improvement.
But the best, most expensive, but only sure fix is new syncros $$$
91 MR2
Looking for Sparco steering wheel, or Momo Jet (black) wheel. Email pics, let's make a deal!
Old 08-18-2004, 09:59 AM
appleburger's Avatar
appleburger appleburger is offline
Re: Tranny grind between 1st and 2nd
yeah, the syncromesh worked wonders for me. also try the brass shifter bushings from twosrus.com
Old 08-18-2004, 11:30 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
i'm resigned to double clutching properly till i take the engine out and i'll rebuilt the tranny...
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
Old 08-19-2004, 12:19 AM
I'm planning on doing an engine/ tranny swap within the next year,3rd gen 3s-gte, if i flush the tranny get redline tranny oil,or that penzoil do you think it will last me long enought to get to the engine swap. The car has 135,000 miles on it do you think it'll get me to 200,000 without a rebuild, so i dont have to waste any money going to a swap
Old 08-19-2004, 02:28 AM
TRD2000's Avatar
mine's apparently been doing it for 5 years so far...
as i said ... learn to double clutch... my grandma can!
Synchros are for pussies anyway, they were made so people who couldn't drive could drive!
Old 08-19-2004, 07:05 AM
riiiight....anyway, i'm telling you, get pennzoil or gm synchromesh and the brass shifter bushings!!! your tranny will feel like its brand new. don't waste a ton of money on the redline! the syncromesh is like 2 or 3 dollars a bottle and will help tremedously!
Old 08-19-2004, 12:49 PM
To: Appleburger I looked up those tranny bushings, and they were not that expensive, alot less than i thought, so if i change the shifter bushings and change the tranny oil with the pennziol synchromesh, it should get rid of or get mostly get rid of the grind?
To: TRD2000 Doesnt double clutching get old after awhile just for everyday driving?
Well I'm gonna try the new bushings and tranny oil, if anyone has any other suggestions, please let me know, cause i dont want to rebuild the tranny.
Thanks alot
Old 08-26-2004, 04:22 PM
TRD2000's Avatar
only really gotta do it on changes into 2nd, feel sorry for my grandma, as i said they never had it so if you wanted to drive you had to do it every gear.
only REAL problem it gives me is trying to launch hard and change fast into 2nd. but it's not worth pulling the engine and tranny out just to fix one synchro, so it's worth putting up with till i need to do the clutch or something big, then i'll do a full rebuild on the tranny, cause its been like it for a while so the 2nd gear teeth probably need brushing .. or filling most likely.
