Electrical drain
I have a 98 Caravan with the 3.0 V6 and the battery will go dead after its parked for a couple days. The battery reads 12.75 volts. Engine running 13.65 volts and when I remove the postive terminal and read between post and terminal I get 9.65 (To much!) I have pulled all fuses (In the engine compartment fuse box and under the dash and it still reads 9.65 volts. I disconected the alternator and it still read 9.65 volts. Any ideas where I'm loosing curent! Dome and interior lights check out ok? Help!!!
i had the same problem with mine. i noticed my rear defogger was working and the switch was not on so you might want to check to see if anything is running it turned out my switch was bad hope this might help
