Old 08-17-2004, 10:15 PM
96CivicEX06's Avatar
96CivicEX06 96CivicEX06 is offline
Send a message via MSN to 96CivicEX06
Window problem
I recently got my windows tinted (not sure if that matters) and today I rolled down my passenger window and it seemed like it went down hard (I did this after a rain). About 10 minutes later it started to rain again and I attempted to put the window back up but it only went nearly 1/2 of the way up until it jammed. It seems as though it's being caught on the weatherstripping. When the window is fully down it is "floppy" meaning that it's easier to jiggle the window. The driver's side doesn't jiggle at all. What is the problem and what would I have to do to fix it?
Silly ricer, wings are for planes
Old 08-17-2004, 11:20 PM
apexigod apexigod is offline
Banned
Re: Window problem
All Honda Civic 96-00 windows are fucked up, take it to Honda and have them fix it.
the braces in the door panel are off track, or broken....it costs about $250 to get it fixed, maybe more...depends on your local Honda dealership.
Old 08-17-2004, 11:34 PM
MexSiR's Avatar
MexSiR MexSiR is offline
Send a message via MSN to MexSiR
Re: Window problem
Yep, Honda 96-00 are a piece of shit...my two windows fucked up, not the electric elevator, but the plastic things in the middle, cost me 145 dollars to fix the right one, the left one does not work.
Honda Civic 1999 EBP SiR
Im not as fast as I am furious.
1/4 mile = 15.347 (sealevel)
Porsche RS America
BMW 323 01
Pictures of my ride (Pictures)
Old 08-18-2004, 10:08 AM
I have a helm's manual and was thinking about fixing it myself so I wouldn't have to pay a lot of money, think it would be too hard for a "home-mechanic" and myself to fix it?
Old 08-18-2004, 03:28 PM
EKhatchCX97 EKhatchCX97 is offline
Send a message via AIM to EKhatchCX97
actually its not that hard...just a little time consuming, because you have to remove the entire door panel, and all, the problem you might run into is having to fix/put back the window into the track and everything, pretty easy job though....
Old 08-18-2004, 06:03 PM
Re: Window problem
OK cool, I'll let you know how it goes.
Old 08-19-2004, 10:31 AM
wheel1856's Avatar
wheel1856 wheel1856 is offline
Send a message via AIM to wheel1856
In my experience, I have found that new bolts, or a washer (or small extra washer) on the retaining bolts for the window regulator arm help to prevent them coming loose. Also, if you take the door apart and make sure the lifting arm isn't bent up or anything, and put plenty of generous grease on the working metal parts ( I found bicycle chain grease to be wonderful for this, thin and waterproof)
good luck
"Why yes, this is a GS-R."
Old 08-19-2004, 11:35 AM
T-Racer's Avatar
T-Racer T-Racer is offline
Send a message via MSN to T-Racer
Re: Window problem
i had to tighten my bolts on my rod the other day, works fine now.
My name is Tyler, don't be afraid to call me it.
Originally Posted by BlaZeNSmoKe
So next time I see a deer and I can't dodge it, best believe I'm gon' speed up. Cause he ain't gon' get the best out of a accident with me, no sir.
Old 08-19-2004, 05:28 PM
Re: Window problem
Fixed it... it was way out of the track, so I had to take out the retaining bolt, put it back in, then tighten to where it was again.
Bad part is that the tint ripped from where it jammed, think I could get away with telling them "it bubbled" for a warranty repair?
