Old 08-17-2004, 09:51 PM
hartbeat hartbeat is offline
Unhappy Need help locating keyless remote module in 1992 Park Ave.
Please....help me to locate the keyless remote module on my 1992 Park Ave. Ultra. I need to change it out. Thanks in advance........
Old 08-19-2004, 09:49 PM
Jed Rule Jed Rule is offline
My 1995 book says: The Remote Accessory Control Module (RAC) is behind RH side of instrument panel, above sound insulator (kick panel) next to relay center. The chime module is there too.
Old 08-23-2004, 06:37 AM
Re: Need help locating keyless remote module in 1992 Park Ave.
I am not finding it there. The sound from the chime module sounds like it is coming from the area behind the radio.
Can anyone look this up in a '92 shop manual?????
Old 10-10-2004, 12:51 AM
Clay_Bee Clay_Bee is offline
I just saw mine looking for an A,C problem. It is under the dash, passenger side. If you pull plastic kick panel (this is the panel under the knee bar. The panel that covers where you reset the oil change monitor). Pull this panel down, get your head under the dash and look up toward the windshield with a good flashlight. You are looking for a fuse block with fuses and relays. The module should be clipped to the bottom of this fuse block. Its black, and about the size of a deck of cards cut in half, with 6-8 wires plugged into one of the narrow sides. Its a pain to see, but easy to slide out.
