Go Back   Automotive Forums Car Chat > Jaguar > S-Type
Old 08-17-2004, 08:48 PM
unwired unwired is offline
S-Type Radio Problems..
I have a 2001 S-Type 4.0 with the Premium Audio, I am getting horrible radio reception through the antenna embedded into the rear window. The sound system is fine, CD's aren't a problem. When I put the radio on, it is fine when the car is stopped, but when I start moving I get static, volume changes, and lots of fuzz. Anyone else have this problem and know if there is ANYTHING I can do about it?
Old 01-17-2005, 10:05 PM
toobz toobz is offline
Send a message via MSN to toobz Send a message via Yahoo to toobz
Re: S-Type Radio Problems..
I have a 2001 S-Type 3.0 and having the same problem, it is really frustrating. Did you figure what the problem is? And also, is there a way to tell whether or not you have premium audio. Any information on this would be great, Thanks!
Old 01-19-2005, 06:12 PM
cobra73_nl's Avatar
cobra73_nl cobra73_nl is offline
replace the rear windscreen /antenna or you might have a problem with the amp in the boot (left ontop of the cd changer)
Old 04-28-2005, 02:25 AM
DON JULIENNE DON JULIENNE is offline
Re: Re: S-Type Radio Problems..
I'm new to the forum. I have a 2001 S-Type 3.0 with this same problem started a few weeks ago. You're right really frustrating. Premium has all the extra speakers.CD and tape sounds great but when the car moves radio just gets fuzzy and static. When it stands still radio sounds great. I saw the response on changing the amp in the trunk. Did anyone try that out there ? Changing the windscreen/antenna sounds real extreme ?? Thanks
Old 04-09-2010, 04:59 PM
Charles Ferguson Charles Ferguson is offline
I have a 2001 S-type, V6 and I have the same radio static noise. I can hear the engine noise thru the speakers when I accelerate. When I let off the gas, the noise tends to go away. Any thoughts?
Old 08-05-2010, 07:04 PM
danielsatur danielsatur is offline
Clean & use a white lithium grease on antenna and battery connections.
Old 09-07-2010, 06:34 PM
Daniel, thanks for the tip. But where do I locate the antenna and battery connections?
Old 09-08-2010, 11:56 AM
The antenna is in the rear window, the radio amp, and battery is in the lower trunk.
