Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-17-2004, 08:04 PM
CLAYSPST CLAYSPST is offline
Post Ignition Module?
Hey Everyone I Am New Here. Does Anyone Know Where The Ignition Module Is Located In A 98 Contour Se With A 2 Liter Engine?
Old 08-18-2004, 08:22 PM
Re: Ignition Module?
anyone?
WWW.SEDUCTIVECYCLES.COM
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 08-25-2004, 12:51 PM
dxrflyboy dxrflyboy is offline
There is no ignition module. The PCM reads the signal from the crank sensor and triggers the coil pack.
Old 08-26-2004, 01:27 PM
yes there is i have the part in hand i just need to know where it is located. thanks for the info
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 08-27-2004, 07:31 AM
I'll check the shop manual today. The coil pack bolts to the back side of the head. If you can post a pic of the part, I can have a better idea of where it goes.
Old 08-27-2004, 12:41 PM
Checked the shop manual. PCM receives signal from crank sensor & sends ignition pulses to coil pack.
Old 09-02-2004, 09:38 PM
i am at work now i will post pic on friday thanks
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 09-03-2004, 07:31 PM
I Do I Post Pics
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 09-04-2004, 07:29 AM
Click on the post reply icon rather than type in a quick reply. It gives you the option to upload photos.
Old 09-04-2004, 08:45 AM
Ok I Uploaded Them Now What?
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 09-04-2004, 08:02 PM
I'm uploading a jpg image to see if there's any problem...
Old 09-05-2004, 11:18 AM
I went and looked at your photos. I don't recognize it as anything that goes to a Contort ignition system. You might want to take it back to the store and have them reference the part# to see what it goes to. Sorry I can't be of any more help.
Old 09-05-2004, 11:26 AM
well we tried thanks
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 09-11-2004, 08:07 AM
so do you think my problem my be the pcm?
WWW.STUNTLIFE.COM
RIDE WITH SPST!!!
Old 09-11-2004, 09:54 AM
More likely it's the crank sensor, coil pack, or wiring between components. The only way to know for sure is to check for input and output signals using a labscope.
