Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-17-2004, 06:38 PM
MBCaprice MBCaprice is offline
unstable idle, tach bounces around!
Just purchased a 95 SL1. After changing transmission fluid to keep the automatic tranny from slipping, I've noticed a lower then normal idle when the car is in drive. It vibrates the car at stoplights. Additionally when slowing to a stop, the tachometer jumps around a lot when it gets down around 1000 rpms, before it settles down to 600 or so.
Things I've done so far:
Cleaned IAC, replaced TPS, checked for vacuum leaks. I do not want to resort to turning the idle up via the BISS, but may have to. Is there anything else I can look at to obtain a stable smooth idle, and get a smooth engine slow down upon coming to a stop with the car
Old 08-18-2004, 12:15 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: unstable idle, tach bounces around!
a few things come to mind. to start off with, clean the EGR, check the motor mounts, and is it just the tach jumping around, or are the RPM changing too? also, is there any "slamming" in to reverse or drive gears?
Old 08-30-2004, 11:32 AM
tgrudzin tgrudzin is offline
Check the EGR valve. I didn't becuase the cost was $170.00 for the part. It died on the way to work. Cost $170.00, plus towing, plus a missed day of work, plus the mechanic installing the EGR.
Syptoms: on a five speed, it would fail to drop idle quickly between shifts. Then as it started to really jump and die as you tried to start from stop lights. The jumping idle I had noticed months ago, but didn't put it together until the car was repaired. My was a 5 speed, 94 SL2.
The transmission service had nothing to do with the problem.
Ted
Old 10-08-2004, 10:56 AM
dw97sc1 dw97sc1 is offline
Send a message via AIM to dw97sc1 Send a message via MSN to dw97sc1
Change you (ECTS) coolant temp sensor. Get the part from Saturn. Not after market $12-15 10 minute change.
