Old 08-17-2004, 06:30 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
rusty bolts
ok, so im in the middle of taking my gastank oown to put in a new fuel pump.... and the housing that holds the bolt to the bracket borke.. so th bolt just spins when i try to loosen it.. what am I to do with all that gas there?? its not like i can cut it off with a dremel.
Old 08-20-2004, 06:03 PM
bdodge bdodge is offline
Re: rusty bolts
Try taking a screw driver and pry under the bolt head, this will put tension on the broken nut while you attempt to unscrew it. It may get you far enough to cut it off. you can use a dremel, just take a piece of cardboard and use it as a guard for the sparks that fly around
