Old 08-17-2004, 05:23 PM
getusmonster getusmonster is offline
Send a message via AIM to getusmonster Send a message via MSN to getusmonster Send a message via Yahoo to getusmonster
Injector Problem?
I have a 95 tbi 4.3 and i get about 7 miles to the gallon. Just changed filter, plugs wires, cap, rotor and coil but it still smells strongly of gas when you crank it and for the first ten minutes of driving. It also deisels down real bad. any suggestions??????
Old 08-17-2004, 06:35 PM
95silverado 95silverado is offline
It looks like the service engine light would be on. Several things could cause the engine to run too rich. You should probably take the truck to autozone or other parts store and get them to read any codes that the PCM has stored. That would point you in the right direction.
Old 08-17-2004, 09:02 PM
Rbraczyk Rbraczyk is offline
Send a message via AIM to Rbraczyk
Re: Injector Problem?
Aren't the 95's oBDI ? Autozone only reads codes on OBDII
Old 08-17-2004, 09:09 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Yes they are OBDI, you should still be able to use the paper clip bridging "A" and "B" connector pins on the diagnostic link connector to pull codes. Is it TBI or MPI? I would have thought you might be looking at a worn injector, possibly a stuck fuel pressure regulator. Have you changed the fuel filter also? Just some ideas. Hope this helps -Chris
Old 08-17-2004, 09:10 PM
96 starts the MPFI. Everything before is TBI.
Old 08-17-2004, 10:05 PM
I don't know about the chevy pickups with the 4.3 liter V6, but we use to have a 94 Olds Bravada with a 4.3 liter MPFI Vortec, and autozone read the codes when the egr valve stuck open.
Old 08-17-2004, 11:19 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
I'm pretty sure the 95 4.3s were TBI, and they use the same throttle body as 88-95 350s.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 08-18-2004, 07:31 AM
Jeremy-WI Jeremy-WI is offline
There were a few pre-96 4.3L motors that were CPI, I don't know if they were used in a Fullsize but they were used in S-10 Blazers
Old 08-20-2004, 03:41 PM
ITS TBI and no iahvent actually thought about the fuel filter. Good idea maybe ill change that and see.
Old 08-20-2004, 03:44 PM
also no engine code and just made sure the timing was set to 0
Old 08-23-2004, 10:36 PM
my truck looks exactly like chevytrucks 92, only with new mirrors
Old 08-26-2004, 09:43 PM
Its a TBI. The Vortecs (multi-port injection) didn't come out in the trucks untill 96.
Have ya checked for any leaks? You may have a hole in a line.
Could very well be an injector as well. I know you posted last a couple days ago, so you may have the problem fixed, lol.
**1966 Chevy II**
Old 09-02-2004, 10:28 PM
changed the fuel filter and that seemed to help alot with the gas mileage. factory filter with 135000 miles oops. but it still diesels down like a bitch
