Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 08-17-2004, 04:04 PM
proformancewanabe5 proformancewanabe5 is offline
I found a 300z
1996 300zx TT w TTops I found one at from all places, auto trader for 12grand problems: Rear veiw mirror needs replace
Right side view mirror needs replace
Right turbo seal leaks oil
Cracked bumper
Cracked side skirt
This car has about 64,000 miles on it. The owner says that it drives
good down the road
I did a kelly BB on it and came up with 18 grand I am new to 300zx
so if you guys could help me out with any info I would be very thankful
Old 08-17-2004, 04:56 PM
DemonYugo DemonYugo is offline
Ill tell you what. I was just out looking at 2 300zx. And those cars are only worth anything if the body is in emaculate condition, in if theres no rust. And i think thats still a little high priced. Theres a mechanic owned 300zx NA over here like 93 and hes asking 5k for it.
Old 08-17-2004, 05:07 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Re: I found a 300z
Cracked bumper
Cracked side skirt
good down the road
Sounds good to me... take caution with that seal leak though... everything else is just minor detail...
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
Old 08-17-2004, 07:59 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Depends on where the turbo line has the leak. If its something easy like the feed lines to the oil cooler thats fine, probably twenty minutes under the car to fix. If its something more along the lines of a leak from the oil return line under the turbo...well thats a little more complicated but still fairly simple. Its not engine threatening, probably the biggest problem there is having to put in more oil and having it leak all over your engine (Unless you plan to whip on the car, in which case that oil seal should be tight as a drum. Also if you plan to upgrade the Z to whipith on it more, I suggest you win the lottery). 12k sounds like a reasonable price, especially since the rest of the car seems to be in great condition from the pictures, including a very clean looking tan leather interior.
(I'm assuming this is the car you are refering to).
Decent body kit even, most look like ass, even if the bumper sticks out too far on the sides when you look at it from the front. If you want to replace that I suggest a OEM 99' JDM front bumper, they look badass. And IMO, keep the stock wing, most aftermarket ones look like a damn radar antenna (Like this dipshit).
Bottom line: Seems like a pretty good deal. Just check it over as best you can and make sure its exactly what you want before dropping cash on it.
Old 08-17-2004, 09:42 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: I found a 300z
that seems about the right price. like broke said, the oil leak SHOULDN'T be too major. and if it is the car that broke posted, then i would definitely think about getting it.
ZedEx Crew Member #2
Old 08-17-2004, 09:56 PM
JCCR JCCR is offline
Re: I found a 300z
it sounds like a good deal just becarefull! don't believe everything the owner says.if you have acces to the car, drive it and take it to a mechanic and try to get and estimate on how much your gonna spent. obesly the owner didn't fixed the turbo leak cause its to expensive. if it wasn't expensive the owner would of fix the turbo leak issue and sell the car for about $2000 more.
thats what i would of done if it was my car
*Reads Freaks sig*
I thought your anti-drug was crack.
Anyway, that brings up a good point. I think of things as I can do them, in this case, the oil leak is a inferior opponent who would be crushed under the crushing weight of my crushing automotive repair power. Others may have to turn to outside sources. However, I can't imagine that it would run more than a few hundred dollars provided its nothing more than a gasket or hose leak. If the turbo is cracked or some crazy crap like that then you can kiss affordablity good bye. But it sounds like a small problem to me. But then again, I'm a total gimp.
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 08-18-2004, 02:41 PM
Thanks for everybodys help, I am still thinking about it. he also said that all the work adds up to 2500 I called him to get an adress for mapquest but he gave me a weird adress so I just go down to toledo and get directions from there.
