Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 08-17-2004, 02:25 PM
koreanspeed koreanspeed is offline
help
sumthins wrong wit my car.. when i first put it in drive it drives 4 like 2 seconds then it wont go.. like its in nuetreul or its not getin any gas i. but then ill put it in park then back in drive then its ok.. wuts wrong with it?
-[I belong in tard farm]-
Old 08-17-2004, 02:58 PM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
Re: help
It may be poping out of gear.
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 08-17-2004, 06:13 PM
Re: help
ya.. should i get that fixed and is it gona cost alot of money?
Old 08-17-2004, 06:37 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Have you bothered to check the transmission fluid?
If it's low, it'll act up on you.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 08-17-2004, 06:38 PM
Re: help
oooo ok thanx ill check it... or ill have it checked,lol is it easy 2 check?
Old 08-17-2004, 07:06 PM
-The Stig-'s Avatar
On Fire!
Um...
It's pretty complicated.
But I'll try to make it as simple as possible... Cause even I forget how sometimes.
  1. Start the car.
  2. Drive it around the block.
  3. Park the car.
  4. Leave the motor running.
  5. Pull that little latch under the dash that pops the hood.
  6. Get out and open the hood.
  7. Marvel at the beast that is your Hyundai.
  8. Look for the dipstick that says Trans or Transmission.
  9. Pull that dipstick out.
  10. Wipe it clean.
  11. Put it back in.
  12. Pull it back out... and check the level.
  13. If it is below the recommended mark... add more fluid.
  14. How do you add more fluid? You ask.
  15. Get a funnel.
  16. And put it in the same hole the dipstick came out of.
Go check it now...
Old 08-17-2004, 07:13 PM
Re: help
wow that sounds hard..,lol umm.. shouldent i not drive it b4 i check it? idk but like wit oil or sumthin if u check it when the engine is hot its ummm... not good,lol anyother ideas wut could b wrong wit it? ill check the fluid 2morow,lol
Old 08-17-2004, 07:25 PM
-The Stig-'s Avatar
On Fire!
No, you have to check it when the motor and more importantly the transmission is up to temp. So yes, you have to check it while the motor is running and the transmission is in Park.
So go for a short drive, come back and check it. The tranny fluid has to be warmed up to get a accurate reading.
Old 08-17-2004, 07:32 PM
Re: help
ok.. it cant b 2 warmed up right? like can it get 2warmed up?.. lol sry 4 all the stupid questions,lol
Old 08-17-2004, 08:18 PM
-The Stig-'s Avatar
On Fire!
lol it's ok... lol no it cant be too warmed up, just do like i said. lol...
Old 08-17-2004, 08:20 PM
Re: help
ok thanx
Old 08-17-2004, 08:51 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Thumbs down
Next time you should realy post specific stuff like this in the elantra forum, go check it out, if no ones there (wonder why?...) try another hundai forum like the tiburan (know I spelled that wrong).
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-17-2004, 09:12 PM
-The Stig-'s Avatar
On Fire!
Re: help
Good point... glad I thought of it.
Old 08-17-2004, 09:31 PM
Thourun's Avatar
1995 3000GT VR-4
Old 08-17-2004, 11:03 PM
twospirits twospirits is offline
Ex-Janitor of AF
Re: help
You got that right.
BTW, The reason why some forums like the Elantra might have less posts is because some just post their postings in the wrong section. If more members started to post in their own sections we would have more threads in there.
TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know.
Remember, the "No" is always there, you are just looking for the "Yes"
Members please read: Guidelines
