Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-17-2004, 01:51 PM
bigginstm@hotmail. bigginstm@hotmail. is offline
Question ABS light and Fan problems
My ABS light is coming on, however the only problem that there appears to be is the car makes a humming type noise when you turn left on the highway (it's quiet when you go right), recently the fan on the air system won't blow on 1 or 2, but 3,4, and 5 work fine. I don't know if they're connected or not. The fan went out a couple of days after the abs light. I know abs takes up some juice, so I don't know if they could be related. I have a 99 Malibu with the 3.1 V6 thanks for the help
Old 08-17-2004, 03:39 PM
BeatnikTermite BeatnikTermite is offline
Re: ABS light and Fan problems
No, they are not related.
ABS:
Fans:
http://www.automotiveforums.com/vbul...d.php?t=199000
Old 08-17-2004, 04:29 PM
johnholl johnholl is offline
the blower motor resistor is defective and must be replaced. This resistor is accessable on the passengers-side, behind the glove box. [not the easiest job]
as far as the humming... you may have a bad tire or front wheel berring. have it checked by a reputable mechanic.
as far as abs... check all the fuses and wheel sensors.
Old 09-12-2004, 01:35 AM
Lance CA Lance CA is offline
Heh, just wanted to say thanks for the info that you posted about the heater fan resistor. It was a problem I'd been chasing for a while. Again Thank you.
