Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 08-17-2004, 01:24 PM
lifetrddeath lifetrddeath is offline
Send a message via AIM to lifetrddeath Send a message via Yahoo to lifetrddeath
Grille guard trouble NEED HELP!!!
I went out to install my Manik grille guard today when I ran into a few problems. 1) It bolts onto where the tow hooks are and the bolts holding those tow hooks on were not going to be removed by the turn of a simple wrench. So with no impact tool to my rescue I gave up. 2) Tomorrow I'm getting a 5 1/2 lift done to my truck, with 2 1/2 being a body lift, 3'" suspension...which will sit my bumper/grille up almost 3 inches from where it currently is, nestled by the two hooks. So now I figure, wait, my grille guard probably won't apply correctly anymore...will it? Anyone know of a quick fix or some hardware that can be of any help?
Old 08-17-2004, 04:47 PM
Vroom2's Avatar
Vroom2 Vroom2 is offline
Re: Grille guard trouble NEED HELP!!!
Can't say for sure, but it sounds like the grille guard will sit 2.5" lower.
FYI - I just had to remove my tow hook bolts too. They were a challenge, but a 1/2" drive ratchet loosened them just fine - I'm sure a 3/8" would have as well. Leverage is the key...unless you're Hercules you'll never get them loose while laying on your back. Using the right one as an example, if you sit upright, facing the left tire, you'll be able to pull the wrench toward you to loosen the bolts.
Good luck with everything...
Take care,
Jerry
Take care,
Jerry
'03 GMC Yukon Denali; www.suvworld.com/vroomvroom
'04 GMC Yukon Denali XL; www.suvworld.com/mrsvroom
'04 Toyota Tacoma XtraCab V6 4x4; www.toyotatruckworld.com/vroomvroom
Old 08-17-2004, 04:58 PM
dfskinner dfskinner is offline
Also may want to try a little WD-40 on those tow hooks. Good Luck.
Dennis
Old 08-20-2004, 01:52 AM
Taco_Jon Taco_Jon is offline
Send a message via AIM to Taco_Jon Send a message via MSN to Taco_Jon
Hey I installed my grille gaurd and ran into the same trouble but with the easy wrench spray (like wd-40) and a air compressor i got the tow hooks off. good luck
