Go Back   Automotive Forums Car Chat > Racing > Drag Racing
Old 08-17-2004, 12:51 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Improve top end performance?
well i just started getting into racing this summer when i bought my 2001 Cavalier Z24, i know most you will think its a joke, even more so when i tell you its an auto, bit a for a 20 year old with an OUIL on his liscense it works out alright. Anways heres a slip from my first time ever at a track, i was in my cavalier. It seems to do really well on my 60ft but after that it just seems to slowly die. The car stock is rated at 150HP @ 5,500 RPMS and 155lbs TQ @ 4,400 RPMS. I usually launch around 2k RPMS. Also being i was such a noob, i never adjusted my front air tire pressure to gain traction so i did slip some off the start. IT was also a hot high 80s low 90 degree day. But my main problem is once it gets into 3rd gear at like 70MPH the car just falls on its face. Keep in mind the car is stock right now and when these times were run.
Reaction: .552
60FT: 2.312
330FT: 6.753
1/8th ET: 10.314
1/8th MPH: 68.47
1,000: 13.466
1/4 ET: 16.174
1/4 MPH: 83.63
Im pretty sure with the right tire pressure and cooler day high 15's are well within my reach, but i think the area i need to work on most is my trap speed, what are some of the best ways to gain high end power without losing low end tq?
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 08-17-2004, 01:49 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Re: Improve top end performance?
Intake and exhaust are always the first steps ...
You may want to read this:
http://www.jekylhyderacing.com/StoryTweakHorsepower.htm
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 08-17-2004, 02:04 PM
TechX's Avatar
TechX TechX is offline
Are you shifting or just leaving it in D? Air flow is very important in the highend. Like said about intake and exhaust.
Old 08-18-2004, 12:07 AM
-Jayson-'s Avatar
i have intake, but im skeptical of exhaust, what kinda HP increases could i see with a fulle xhaust setup?
2009 Ninja 650 R
stock for now...
Old 08-18-2004, 10:37 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: Re: Improve top end performance?
Id say if you did headers and a full catback exhaust, your looking at 10 hp.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 08-18-2004, 11:32 AM
big1's Avatar
big1 big1 is offline
Where you live isn't stated.If it's legal in your area you can also go with a low or no back pressure "CAT". This will improve exhaust flow.
You stated the horsepower and at what RPM,but you didn't say what torque and at what RPM. This RPM determine's your shift point's if your manually shifting.
At what RPM are you crossing the finish line ?
Old 08-18-2004, 03:32 PM
-Jayson-'s Avatar
umm i did state TQ, but again its 155lbs @ 4400 RPMS. about the finishing RPMS, im not really all that sure, last time i was at the track was june. Its prolly close to 3,000-4,000.
2009 Ninja 650 R
stock for now...
Old 08-20-2004, 04:19 PM
-Jayson-'s Avatar
well i figued id work on getting RPMS to get up faster so i ordered a few things. Not sure how long shipping is, hopefully they will be here by next friday.
RSM Racing 2.4L Alternator Pulley
RSM Racing 2.4L Crank Pulley
RSM Upper Engine Mount Insert
2009 Ninja 650 R
stock for now...
Old 08-21-2004, 07:01 PM
SuperchargedGS SuperchargedGS is offline
with going with headers and a catback exhaust you with loose a noticble amout of torque so keep that in mind. try a larger throttlebody, cam will help a lot in top end also. try this website www.mantapart.com
Old 08-21-2004, 09:05 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Well, I don't know about for a 4-cylinder or V-6, but adding headers and exhuast sure won't make ya loose torque in a V-8, lol.
Anyways, it would be alot of money and alot of work, but how about a new intake (not air intake)? This would go much further with improving flow then anything else, lol (aside from head work).
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 08-21-2004, 11:37 PM
-Jayson-'s Avatar
well after i get the light weight pulley, under drive pulley, and motor mounts paid off, im gonna look into either a 59MM throttle body or i was thinking about porting and polishing the head.
2009 Ninja 650 R
stock for now...
Old 08-22-2004, 12:12 AM
porting the heads will help alot, but if you do that you need to get your intake matched, and you need a header. If not then you will just bottlekneck your improvements.
**1966 Chevy II**
Old 08-22-2004, 04:55 AM
if you get your heads P&P, intake manifold and a larger throttlebody then you could get a catback and header. I wouldn't want to loose what torque I have though which in your case is 155. I had a clogged muffler that was only letting a bout an inch of exhaust out of my car. I scaned it and it had 440 FT.LB. of torque. I got the muffler fixed and now I only have 370 FT.LB. but I gained big top end from it.
Old 08-25-2004, 05:34 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
You don't go from 440 lb.ft. to 370 from a clogged muffler. Anyway who leaves a stock muffler on a 440 lb.ft. torgue monster(and 1 muffler to...). You can't pull that past us. You get the BS.
Old 08-26-2004, 08:15 AM
OK, i was just going by what the tech 2 scanner said. I don't have a stock muffler. its a dynomax super turbo and it went bad. the back plate of the muffler was bent over the outlet hole and only about one inch of gap was showing. when I scanner the car it showed 440 FT.LB of torque and when I put a new one on it would only show max of 370ft.lb. I have a full 3 inch exhaust from ported manifolds with a supercharger, 1.8 roller rockers, custom computer, smaller supercharger pulley, P&P throttlebody and a cold air intake. I am not B.S.ing
