Go Back   Automotive Forums Car Chat > Warehoused Archives > Introductions
Introductions Welcome to AutomotiveForums.com. Introduce yourself here so we can get to know you better.
  Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-17-2004, 10:37 AM
race2 race2 is offline
Accord cyl' pressure specs , please
I need tune up and cylinder compression spec's
on F22 and F23 engine .
BTW
Got the Harbor Fright $10 compression tester .
Garbage ! It doesn't use the bourbon( spell?) tube
that the expensive gages use .
I got their tire 'flator , and it's gage went to 140 psi
so i moded it to 190 , added the marks and calibrated
it with a small camp stove propane bottle .
I now have a $200 comp' gage .
Soak the propane bottle at a known temp for at least
an hour . It's surprizing how much more accurate
your gage will be than your buddies expensive gage !
I also add a one-way at the very tip that goes into the
spark plug hole ( improves accuracy a bit) . But don't make it
dissassemble from the engine side or maybe the parts will
fall inside the engine . Mine disassembles to the gage side
so if it loosens and comes apart , it will be captive in the
fitting that goes into the spark plug hole .
Iso-Butane and Propane mix are used to replace R12 but
the penalty is $10,000 . Use pure P' but pressure is 50psi
higher .
( Governer wants to protect his crony's patent on 134a)
Old 08-17-2004, 11:02 AM
lamehonda's Avatar
lamehonda lamehonda is offline
Re: Accord cyl' pressure specs , please
you should post this in the accord forum. you might get more help
