Old 08-17-2004, 10:29 AM
Hypnotica Hypnotica is offline
I think its broken...
I think i blew my engine but it still turns and people tell me its not blown its got something else wrong. When i broke it it was knocking really loud and lost all the coolent and oil then it locked up but now it turns. Does anybody know whats wrong and what should i do. Should rebuild the engine or swap it out for something better and what swap would be best. Im pretty sure its broken. Its a 98 GST.
Old 08-17-2004, 10:31 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: I think its broken...
Compression test.
What exacly happened....your description is too vague.
Kris
2012 Genesis Coupe 2.0t
Old 08-17-2004, 10:38 AM
Well i was going out of town to trade it in so put oil and coolent. Half ways there it started smoking and over heated so i pulled over. Then i started heading back and it was knocking very loud then it just locked up wouldnt turn or do anything and was very hot. After i got it towed back a friend put oil in it and it was turning but it wont start.
Old 08-17-2004, 10:41 AM
More specifics...this vague stuff won't fly.
Why did you put oil in?
Why did you put coolant in?
How badly did it overheat?
Did you drive after it overheated?
Describe the knocking sound.
More than likely, you trashed the head.
Kris
Old 08-17-2004, 05:29 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
sounds like some1 forget to put the radiator cap back on...
[IMG][/IMG]
Old 08-18-2004, 01:20 PM
I put oil cuz it was low and coolent cuz it was low the radiator cap was on. It was smoking and the cams were glowing red thats how hot it was. I stopped to let it cool down and then drove it again. I started knocking like someone was slamming the engine with a hammer under my hood. Then it locked up the pistons and cams would not turn at all i would try to start it and it would just grind. I got it home put oil and coolent and it started tuning but still wouldnt start. I dont know why there was no oil and i dont know why there was no coolent.
Old 08-19-2004, 05:34 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
your cams were "glowing"?!? do you not watch your temp gauge? and the knocking you heard was most likely either your pistons hitting the cylinder walls or your connecting rod bearings are gone and the connecting rods were slapping against the crankshaft... take off the oil pan and see if you can move the connecting rods or not... if not and they are tight, then its your piston rings! and my guess with the head is it's fucked... "glowing" cams are not a good thing! i cant gaurantee its bad without seeing it first but its my best guess~ good luck man, let us know what you find when you take off the oil pan!
Old 08-19-2004, 01:14 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
aren't the cams under the valve cover???
Old 08-19-2004, 01:27 PM
OnefistedPirate OnefistedPirate is offline
Banned
Yes, but above the valves...
At that temp I can honestly say the block could even be warpped. Out of all the 4g63s I've delt with I have yet to see a block warp. But I have also never seen red cams.
That is just insanity.
I find it hard to belive your timing belt is still intacts after such a heat range. I wouldn't even attempt to rebuild a motor that went through that. lol
Old 08-19-2004, 01:48 PM
EclipseRST's Avatar
Banned
wow an actually well written and no pirate talk post! i'm impressed! i dont have a problem with you man, just lose the pirate act and you'll be fine!
Old 08-19-2004, 02:11 PM
Re: Re: I think its broken...
You'll find humor in him yet, Jake.
Kris
Old 08-19-2004, 02:13 PM
Banned
Arrrrgggg Jacob...... Please leave the off topic in the off topic areas... Eyeye? Arrrggg....
Old 08-19-2004, 02:17 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Re: I think its broken...
I think we need to break out the flame thrower
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 08-19-2004, 02:35 PM
If he got banned for not speaking English, this forum could use a good cleansing of equally retarded posters who AREN'T joking.
Kris
Old 08-19-2004, 02:37 PM
Agreed
1997 Spyder GS-T
5-Speed
