Old 08-17-2004, 06:27 AM
Tikiman's Avatar
Tikiman Tikiman is offline
Orange peel problem! Why?
OK, I've sprayed my last 3 models with Tamiya spray cans, all of them Revell models. The first one i did i used TS-19 (metallic blue) and then a clear coat. Both went on with no orange peel. Then i used TS-14 (black) on a diferent model and it went on fine. No orange peel. Then for my last model i used TS-31 (orange, lol) and it had an orange peel effect all over. I used the same method for all 3 and they are all made by the same company, so i assume the plastic is made in the same way, and all the paints are made by the same company. Why is this happening?
Anyone else had the same problem?
Old 08-17-2004, 07:05 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Orange peel problem! Why?
it is simple it has just dried to quick, maybe you sprayed from a bit to far, or you were in open or the can was not warm enough, or you didn't shake it well or you applied it to heavy there is like milion reasons, but it can be fixed for sure, I belive you can do it, a bit more work but you will be pleased.
Sasa Jelic
SCALEMAKERS
Old 08-17-2004, 10:27 AM
Tikiman's Avatar
Thanks. Maybe it was all of the above.
Anyway i am not going any further until i have sorted it. I am going to sand it smooth and then spray on some clear gloss. Hopefully that will work. I just need to sand it enough to remove the orange peel but without taking any of the actual colour off.
Old 08-17-2004, 10:31 AM
Martbee Martbee is offline
Originally Posted by Tikiman
....I just need to sand it enough to remove the orange peel but without taking any of the actual colour off.
Then, watch out for the edges !!!
If you clear coat it... be sure to have the problem solve or you'll have an orange peel clear... pretty ugly !
Old 08-17-2004, 11:13 AM
Tikiman's Avatar
Yeah, i need to be very careful. I really want to do a good job on this one. I got some plans that are a bit experimental so it would be nice if it turned out well.
What's the best way to apply the clear coat? I'll be using Tamiya clear spray can.
Old 08-17-2004, 12:21 PM
mike united's Avatar
mike united mike united is offline
Same as the paint...........keep the can warm, spray evenly about three or four coats.
Mike
Old 08-17-2004, 01:23 PM
Tikiman's Avatar
Thanks Mike.
Old 08-17-2004, 01:37 PM
benzfan's Avatar
benzfan benzfan is offline
Question for those that use clearcoat
Do you still compound the paint , get a shine and then spray clearcoat?
If so does it have a problem adhereing to the paint?
Or do you not compound at all, spray the clearcoat and then compound the clear?
Old 08-17-2004, 02:25 PM
Jaymes's Avatar
Jaymes Jaymes is offline
1. paint
2. clearcoat
3. compound
Old 08-17-2004, 06:35 PM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
i paint
compound
clear
compound
Ed-
Old 08-18-2004, 05:49 AM
I paint... then paint again...
After that, depending on the result... if it's OK the first time why bother ?? No compound, no wax, no sanding. But if it's not OK...
Sanding and compound.
Clearcoat mist... then again with a wet or two.
Then again... if it's OK don't touch if not:
Ps... sometime it's just sanding between coat... not always compounding.
