Old 08-16-2004, 10:58 PM
youngmanvr4 youngmanvr4 is offline
How much oil?
Hey...as some of you know i have a 95 3000GT base. I changed the oil about 1000 miles ago. I put a little heavier oil in hoping that it would stop making my oil pressure gauge go down even tho i knew i had pressure and everything was fine...but it scares me for about 2 secends when i look over and see that my oil pressure is down to nothing. So like i said...i put a heavier oil in. But now my lifters are ticking alot louder then they did before a changed the oil. So i'm going to change back to a lighter oil a see what happens. But my question is how much oil does it need? I forgot what i put in last time. And when i changed it last time i didn't know how much i needed in the first place...i just guessed. I looked at stealth316.com and i couldn't find anything there...witch i think is odd. But i would think one of you would know (i would hope anyways)...so if you could help me out that would be great. Thanks!
dsm97gsx is now youngmanvr4.
94 vr-4 with 58k.
Mods: K&N FIPK, HKS EVC IV, HKS boost gauge, testpipe, EGR by-passed.
Sound: Profile Chrome and Gold amplifier (200W) and (2) 10" Red Cone Sony Xplod Subs.
Coming soon: Stillen downpipe, DN rear pre-cat, Defi boost and EGT gauge's with control unit on A-pillar.
Old 08-16-2004, 11:14 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I'm looking into changing my oil in the next few days, what do I need in terms of tools? What weight oil should I use? Ahd how the F#&$ do I get under the car!
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 08-16-2004, 11:30 PM
StealthModifier StealthModifier is offline
Re: How much oil?
Thourun.. all u need is an adjastable wrench to unscrew the screw in the oil pan.. and just jack up the car on the passenger side... and what i used in my car was Castrol GTX 10W-30.. not sure if thats what they call for.. but i think it is...not sure how many quarts either
Old 08-16-2004, 11:40 PM
Thourun's Avatar
Does anyone know the part number of the oil filter and if it is 10W-30?
1995 3000GT VR-4
Old 08-16-2004, 11:48 PM
Re: How much oil?
Thats what i'm useing now and thats what the new oil is too. Only i put 20W-50 last time i because the ports that are less then 1mm in the lifter its too heavy of a oil to run in thos little ports. The new oil i'm going to put in is 10W-30. If i were you i would get a new filter. I have ramps (two of them) that i used to get the car up. When i say ramps i mean metel ones like you would see a wal-mart. I'm going to get a two post 10,000 pound lift sometime...so that will be nice to have when i'm working under the car.
No one knows how many quarts need to go in?
94 vr-4 with 58k.
Old 08-17-2004, 12:03 AM
Re: How much oil?
Go to ur local automotive store.. im sure they have oil filters there.. as well as a book to look up the number.. i think each brand has a different number for them
Old 08-17-2004, 12:13 AM
Thourun's Avatar
Yea thats what I was gonna do, anyone know of a site that has a walk through with pics? I've never changed oil before but it sounds realy simple, I've been able to do everything else so far. I'm going to go back to autozone tomorrow and get some oil and a filter.
1995 3000GT VR-4
Old 08-17-2004, 05:12 AM
sLADe781 sLADe781 is offline
Re: How much oil?
Thourun: http://www.team3s.com/FAQoilchange.htm No pics but it's a walkthrough. :o/
Stealth, jack up the car on the passenger side? Isn't the oil pan on the driver side? Do you let it back down while it's draining? I usually have the whole car on some type of stand but it gets so time consuming sometimes to just change the oil. Ugh!
Old 08-17-2004, 07:17 AM
BB1970's Avatar
BB1970 BB1970 is offline
Re: How much oil?
fram part number for the oil filter is PH6811, if you need part number for another make let me know.
you need a fraction under a gallon of oil i.e 4.3 litres up to you what viscosity you use , i prefer 15/40 semi synthetic but thats just my opinion
hope this helps
brian
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 08-17-2004, 01:13 PM
thre3kgt811 thre3kgt811 is offline
ur supposed to fill ur car with about 3 - 4 quarts of oil, after putting on the new filter, then let the car run for 30 seconds to get the oil flowing, then shut off the car, measure how much is on the dipstick. most likely 3 quarts wont be enough i think last time i used close to 4 and a half. but then u just keep measuring with the dipstick till u have enough
Old 08-17-2004, 05:40 PM
Re: How much oil?
Thourun, i just got back from changing my oil. I put in 4 quarts on the dot. I have a Fram Double Guard oil filter and the part numbers on it is (well it has two numbers) the first is DG3593A thats the one i think you need. The other one is A33071. Look for thos two or just ask someone there...or if they have a book there just look it up. If i where you i would use the double guard oil filter. I think it filters alot better. To get the bolt off to drain the oil the bolt size is 11/16...i use a 1/2 inch drive (easier to get off). One thing i like to before putting the new filter on i like to fill the filter almost all the way up. Its just something i learned from my dad. But do make sure you oil around the top of the filter...if you dont...well...we just wont go there. I think thats it. Good luck.
94 vr-4 with 58k.
Old 08-17-2004, 06:28 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Hey dsm97, did you check the oil pressure guage now? is it fixed?
Old 08-17-2004, 08:18 PM
Thourun's Avatar
The biggest hurdle is how to get the car up safely, I could use a jack or two but I would rather have ramps but where am I going to get those for cheap lol. I think I might just jack it up on both sides and reinforce with cinderblocks. Where is the most secure place to put the Jack? I know not on the sideskirt lol!
1995 3000GT VR-4
Old 08-17-2004, 09:17 PM
Re: How much oil?
sLADe781.. i meant jack it up on the drivers side.. i was thinkin of the transmission for some odd reason .. but about putting 3-4 quarts in and lettin it run for 30 mins isnt a good idea.. cuz once u turn it off ull have to wait a few hours for the oil to drain down so u can see exactly how much oil u have.. i say just put 4 quarts in and let it sit there for about 5 mins or so.. then check the dipstick.. i wanna say i put 5 in mine... but im not really sure.. also when u put in a new oil filter.. fill it up with the oil u are going to use first before putting it back on
Old 08-17-2004, 09:22 PM
Re: How much oil?
Thourun, i jack mine up inside of the sideskirt.. where that metal lip comes down
