Old 08-16-2004, 11:51 PM
winlo408 winlo408 is offline
HELP PLEASE!!!! 86 honda accord alternator
ok im trying to change the alternator on my moms 86 honda accord lxi, she told me to bring it to the shop but i said i can do it, i got it loose but it would not come out, their is no space at all for it to come out. have anyone here ever done one before? or have any information on how? any info would help.
she needs the car on wednesday so i have to get it done by tomorrow, pleeeeeeeeeeeeeeaaaaassssseeee help.
thanks
winlo
Old 08-17-2004, 02:00 AM
gitter44 gitter44 is offline
You have to remove the drivers side axle to get the alternator out.
Old 08-17-2004, 02:31 AM
JimmyzGarage's Avatar
JimmyzGarage JimmyzGarage is offline
Re: HELP PLEASE!!!! 86 honda accord alternator
Here's a step by step from autozone's website (i swear i don't work for them ) http://www1.autozone.com/servlet/UiB...3d800cf8ff.jsp
And yes you have to remove the axle like gitter said. Good luck!
Old 08-17-2004, 03:06 AM
thanks for the reply's, so now i have to figure out how to take apart the half shaft. or if any body on this board know's how let me know, step by step, im a neewbie to all this. my friend said becareful and dont miss with anything involving the alignment...?
Old 08-17-2004, 06:31 AM
Re: Re: HELP PLEASE!!!! 86 honda accord alternator
Best thing to do is run to your local auto parts store and but a Haynes manual... Pulling the axle is pretty easy and with the manual you should have no problem.
Old 08-17-2004, 08:15 PM
I haven't work on this particular year, but you have to remove the steering knuckle and the easiest way is to unbolt the lower ball joint and use a 2 jaw puller (you can use a fork but it may goof up your rubber seals) You may be able to just unbolt the upper control arm and swing the unit to the side to get the clearance you need -- just an idea.
Old 08-18-2004, 01:15 AM
cool, i just bought a repair manual, hopefully i'll get this done by 2morrow morning.
thanks for the info
Old 08-24-2004, 01:08 AM
Stereo Stereo is offline
Send a message via AIM to Stereo
since you have a lxi just pull the airbox on the intake you should have have enough room to get the alternator out from the top if you have a carb. car then you have to pull the axle
Old 08-24-2004, 02:20 AM
i already pulled the axle, thanks anyways. does anyone know if the axle is suppose to be flush with the transmission or is their a little gap between them, the reason i ask this because i just put my axle back in and theirs a little gap.
