Old 08-16-2004, 10:14 PM
metis2fast4u metis2fast4u is offline
whats the difference?
between the capable internal psi on an rs/gs to a gst/gsx? its the same engine right? so woudlnt it be the same psi? and how can some poeple run 16psi w/o internal mods? i jus dont get it.
It's only illegal if you get caught......
Old 08-16-2004, 10:57 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: whats the difference?
ok first of all the motor in the RS/GS (420a) is completely different than the ones on the GST/GSX(4g63). so the psi is not the same ,the RS/GS dose not have a turbo. the GST/GSX dose have a turbo ,because of this turbo the motor was built to withstand more horsepower and PSI. from the factory the GSX/GST comes with 13-14 psi.
The motor can also handle about 400hp on stock internals. so this person that runs 16psi, probally just bought a boost controoler and got a new BOV then hit the track and didnt have to worry bout a thing.
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 08-16-2004, 11:06 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
the rs and gs have high compression pistons and the gst and x have low compession pistons...that should explain it all...thats why all the little tubo civics can only run 5 pounds (haha)
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 08-16-2004, 11:12 PM
bclipse bclipse is offline
Well i did see this civic runin 10 psi on it but then the engine started to smoke really bad, and it never turned on again. Its not going to be runin for a long time. Long long time
95 GS-T
'cause everyone thinks they're right, and nobody thinks that there just might
be more than one road to our final destination
Old 08-16-2004, 11:32 PM
i rest my case
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 08-17-2004, 12:06 AM
george536's Avatar
george536 george536 is offline
civics can boost more, but they have to work on internals. they will blow up eventually if they have stock everything. lol not like the 4g63 thats made for it.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 08-17-2004, 01:08 AM
coolguycooz coolguycooz is offline
Wait WTF the STOCK GS-T and GSX can support 400 hp on a stock engine? If so why do people do internals on the GS-T and GSX?
Old 08-17-2004, 01:52 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Because they can!!! lol or nothing better to do and it is fun sh!t
"If you were to get a 91-99 turbo eclipse/talon you wouldn't be a self indulgent weiner with too much bloody money!"
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 08-17-2004, 02:27 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
o0o i got an answer...so they KNOW it'll work and not just say...its good to 400hp...i should be ok...
THEY SAY: o yeah, i reinforced it all, it'll boost 30psi no problem and they never hafta worry!
Don't act like you don't love it.
503/2000
Old 08-17-2004, 05:57 PM
ok, so my next q. how easy is it to swap in a 4g63 into a rs/gs? and is it the same for older dsm's? meaning do they have the same engine.
Old 08-17-2004, 06:04 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
search...
[IMG][/IMG]
Old 08-17-2004, 06:27 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
if you would have done your research like you were supposed to instead of relying on us to tell you, you would know that it would be easier to sell your rs/gs and buy an already turbocharged car. a motor swap is completely retarded because the engine/tranny is 180 degrees opposite in the 4g63 (turbo) than in the 420a (non-turbo) which means you'd have to fabricate pretty much another engine bay, get new wires/harnesses, ecu, fit everything together properly, and upgrade a whole bunch of other shit. that's in the 2g's. the 1g is a different story. the turbo and non-turbo engines are basically the same except for some internals and stuff like that. they should bolt right in and have the same connectors and all that type of shit. you still might have to upgrade a few things but it should work out right.
95 Talon TSI AWD
97 Eclipse GST
Old 08-17-2004, 08:07 PM
well sorry i didnt search, but sometimes its alot easier to just ask since i have the slowest internet in the world. and it takes like 5 mins to load a page, but whatever.
Old 08-18-2004, 12:52 AM
i wasn't trying to be an asshole or anything but that question get's asked like 1000 times a day.
95 Talon TSI AWD
97 Eclipse GST
Old 08-18-2004, 01:09 AM
EskimoMarine's Avatar
EskimoMarine EskimoMarine is offline
Send a message via Yahoo to EskimoMarine
I think i even asked that question...
