Old 08-16-2004, 07:23 PM
BL54's Avatar
BL54 BL54 is offline
Programming Keyless entry Remote 01 Silverado
Anyone know how? Or even how to find out which one of the transmitters work? Thanks in advance
Old 08-17-2004, 11:06 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: Programming Keyless entry Remote 01 Silverado
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
