Old 08-16-2004, 07:09 PM
arnstr arnstr is offline
92 buick-service engine
Hi,
Just got a used 92 Lesabre 118000km
Service engine light comes on after about 5 min driving
&/or up hills
ALDL Reads code 41 ( cam sensor or MEM-CAL/ECM)
I washed the motor, changed oil, and reset the Change engine oil sensor
The light was off for about 1-2 days
Not sure if I jostled a sensor when I washed it or if the Change Oil Reset
helped
I removed the connector off the cam sensor and cleaned it
Removed neg. batt cable to reset code
It's on most always now.
Would changing plugs & wires help
Is the cam sensor replaicable without removing timing chain cover\
Do the cam sensor leads trace to the coil arrangement
Also..The wife has experianced a jerking stall (kept driving though)twice in 2 weeks
once while parking and once doing about 40km/hr
Of course it never does it when I'm driving
reading posts in this forum suggest possible torque convertor lock-up
bad motor mounts, I'm hoping not timing chain(never had jerks when toyota's timing chain went)
Or heres hoping its just a bad ECM or chip
Any suggestions or answers, anyone experiance similar
Old 08-16-2004, 07:33 PM
Jed Rule Jed Rule is offline
Re: 92 buick-service engine
It's more likely the crankshaft sensor. There are many threads with similar problems and the crank sensor wound up being the cause.
Old 08-17-2004, 11:27 AM
3echo9 3echo9 is offline
I doubt it's the crank sensor. Symptoms for a bad crank would set a code 17. The car would crank but not fire. The cam sensor is behind the harmonic balancer and is fairly easy to replace. Just make sure you have a puller and a very long breaker bar.
Old 08-17-2004, 11:38 AM
Old 08-28-2004, 03:09 PM
I replaced the camsensor $50
Imediately service engine light went away
Thats the sensor on the outside of the timing chain cover
remove the splash gaurd to see better and undo 1 bolt
but then...see my next post...
92-wet road fun now tach
