Old 08-16-2004, 06:55 PM
91civicguy's Avatar
91civicguy 91civicguy is offline
Send a message via MSN to 91civicguy Send a message via Yahoo to 91civicguy
what causes cars to smoke??
i have a 91 civic hatch d15b2 completele stock motor. i got a head put on it it is a caburated head could that be the problem right now im fixen to go to the store to buy 4 QUARTS of oil because my motor is bone dry. i just changed my oil like 2 weeks ago my car does not dripp oil i know that for a fact. like whenever i shift from second to 3rd gear and i press the gass a big ass PUFF of smoke comes out . i hope it is just the head well ill be right back. please tell me what the problems could be
Old 08-16-2004, 07:21 PM
cloneboy17's Avatar
cloneboy17 cloneboy17 is offline
i had a carbed 84 accord that did pretty much the same thing.... it was burnin the oil... thats why it smoked... usually if i floored it thru third it would burn it off and run fine... really sounds like your burnin off your oil tho... i used to carry around cases of oil
Old 08-16-2004, 07:51 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: what causes cars to smoke??
yea, mine burns oil only at high rpms or when i step on the gas hard
bad rings and/or leaky valve seals usually cause your car to smoke and burn oil - as long as the smoke is blue anyway
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 08-16-2004, 07:55 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
whoa, what a second. Did you just say you put a carb head on a d15b2? If so, then theres your problem. I didn't think it was possible to do so. The d15b2 is a fuel injected engine, not carb.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 08-16-2004, 08:02 PM
icE_x's Avatar
yikes, i didn't even notice that
get a diff head on there!
Old 08-16-2004, 08:08 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
peer pressure is a big part of it
Old 08-16-2004, 10:40 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
is it blue white grey black, or what?
Old 08-17-2004, 09:03 AM
91civicguy's Avatar
its blue
Old 08-17-2004, 09:04 AM
91civicguy's Avatar
so if i change the head that could be the problem the smoke might stop. because this is a carburated head and i got a fuel injected car.
Old 08-17-2004, 11:54 AM
icE_x's Avatar
exactamundo - and if it still doesn't stop it's one of the other things listed above
Old 08-17-2004, 03:26 PM
V-K V-K is offline
Send a message via AIM to V-K
The head is probably off the D15B (carb engine). When I went from D15B2 to D15B I just assumed I would still get a DPFI engine. Boy was I wrong! :P
The heads are slighlty different from the block.
Old 08-17-2004, 03:31 PM
civic_geek133's Avatar
civic_geek133 civic_geek133 is offline
Send a message via AIM to civic_geek133 Send a message via Yahoo to civic_geek133
a DPFI intake manifold will bolt up to a B2 head...thats what i have
1989 Honda Civic Hatchback **RED**
FOR SALE
Civic: For Sale
Old 08-17-2004, 05:30 PM
krustindumm's Avatar
krustindumm krustindumm is offline
if the stock manifolds fit, then the head is correct.
most likely it is your valve stem seals causing the smoke.
a new head (or rebuild) should solve your problems.
Run a compression test before that and post the numbers just to make sure.
-Dustin
91 Civic Dx Hatch
Midwest Honda's MySpace group
Old 08-17-2004, 06:57 PM
91civicguy's Avatar
Re: Re: what causes cars to smoke??
-Dustin
thanks for the info..
how do i run a compression test??
