Old 08-16-2004, 06:59 PM
johnnyboy5's Avatar
johnnyboy5 johnnyboy5 is offline
Send a message via MSN to johnnyboy5
rebuild or buy
got a 95 eagle talon tsi
head blown, need a whole new engine, rebuild or buy another engine? which one costs more?
will a 99 eclipse stock turbo fit into the talon?
Old 08-16-2004, 07:51 PM
george536's Avatar
george536 george536 is offline
Re: rebuild or buy
Im not sure wich one costs more. but the 4g63 from the 99 will fit into your talon. but i suggest you get an engine from the 1g if your getting another one to put in.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 08-16-2004, 09:05 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
Re: rebuild or buy
doesnt the 1g have some downsides to it....like more of a chance of crankwalk...
Old 08-16-2004, 09:06 PM
george536's Avatar
Re: Re: rebuild or buy
no its the opposite.
-1990 Eclipse GSX
Old 08-17-2004, 10:29 AM
boostdog boostdog is offline
Send a message via MSN to boostdog
Re: rebuild or buy
changing out the head gasket is by far the cheapest..especially if you are doing it yourself. i bought a gasket set for about 100 bucks. when i replaced my head. if u do replace the engine get a 1st gen for sure. larger throttle body, better flowing head, no crankwalk probelms,
Old 08-17-2004, 06:26 PM
dupeto_e's Avatar
dupeto_e dupeto_e is offline
Re: rebuild or buy
get a 1st gen 6 bolt engine. it will coast u alot cheaper than bying a 2g one. and its stronger. do research and see what else you will need for the swap...
[IMG][/IMG]
Old 08-17-2004, 07:38 PM
98GSX's Avatar
98GSX 98GSX is offline
Send a message via AIM to 98GSX
Re: rebuild or buy
ok well i guess i have to help .... hehe go here its A COMPLETE GUIDE TO DOING THE MOD! http://www.roadraceengineering.com/2...torinstall.htm
RST Eclipse GST: Here's the thing I am a scammer... thanks for the $225!!!!! <----THAS JAKE
^^^ hehehe
2000 Ford F-250 boostin' 30 psi
1997 Lexus ES 300
2000 Mazda 626
1999 Mazda Protege
1991 Geo Storm boostin' 10 psi
1998 Eclipse GSX boostin' 16 psi
1991 Oldsmobile Cutlas Calais
