Old 08-16-2004, 05:37 PM
deman123 deman123 is offline
what size torx bit do i use? 2003 Dodge Caravan
i need to know what size of trox bit i should use to remove the calipers on my 2003 dodge caravan so i can replace the brake pads?
Old 08-16-2004, 08:07 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: what size torx bit do i use? 2003 Dodge Caravan
Try a T-45 bit. That should work.
Old 09-12-2004, 12:37 AM
Mark3316 Mark3316 is offline
My method, although not impressive, almost always works: I try one size, and if that one isn't a good fit, I try another.
Old 09-12-2004, 04:50 AM
Rhcmlc Rhcmlc is offline
Send a message via AIM to Rhcmlc
Re: Re: what size torx bit do i use? 2003 Dodge Caravan
I changed the front pads on my Caravan a couple of months ago and the T-45 torx bit fit perfectly.
Old 09-15-2004, 08:46 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
The same method I use.
Went to Napa a few years back and bought one of the bit-kits in a rubber sleeve. 12 different sizes that fit in a 1/4" and 3/8" ratchet drive.
Old 09-28-2004, 12:09 AM
djmarxx djmarxx is offline
I just replaced my front brake pads, and my van has 12mm bolts, not torx bolts. Thats wierd.
