Old 08-16-2004, 02:54 PM
fliptreality fliptreality is offline
my eclipse isn't getting any power to the fuel pump
I need some help my 91 eclipse doesn't get any power to the fuel pump so my car won't start any suggestions?
Old 08-16-2004, 03:01 PM
Re: my eclipse isn't getting any power to the fuel pump
oh and there is power on the wire harness for the efi control relay
Old 08-16-2004, 03:12 PM
Question i really need help
my car will not start it does not get fuel the fuel pump doesn't even come on i have tried using thie fuel pump jumper and nothing i have tested the relay and it tested low on the voltage tests but it still clicks over would it be the wiring to the fuel pump or the relay or something else
Old 08-16-2004, 03:21 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: i really need help
try resetting the ecu
Old 08-16-2004, 03:38 PM
i reset the ecu and still nothing this is frustrating
Old 08-16-2004, 04:20 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
1. don't start 2 threads about the same thing
2. use some punctuation so i can read your posts
If you have power through your fuses and all the way to your fuel pump, but it doesn't come on, it's probably broken. I seriously can't understand your posts that well, so did you test power at the fuel pump?
Old 08-16-2004, 04:21 PM
Question Ok i need more help please
ok i have reset the ecu and my fuel pump still isn't getting any power. my efi control relay is testing at 10 volts w/a 12 volt power applied so is there anything else excluding the efi control relay or the fuel pump wiring?
Old 08-16-2004, 04:23 PM
JoeWagon's Avatar
Banned
Re: Ok i need more help please
If you make another thread about this, I'm going to ban you. This is the third.
Old 08-16-2004, 04:27 PM
go ahead and ban me i don't really care i have tried putting it on the same thread and it says thread closed
Old 08-16-2004, 04:37 PM
Ok this is what is wrong. My fuel pump does not get power, and i have reset the ecu with no results. In addition i have had the ecu tested, it is good.
Old 08-16-2004, 07:29 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
buy a rewire kit, and new fuel pump.
DSM geek
Old 08-16-2004, 07:55 PM
JoeWagon's Avatar
Banned
Since when does the ECU supply power? ECU's are ground. Simple question: do you have power going to the fuel pump or not? Test the wire at the pump.
Old 08-16-2004, 08:03 PM
No there is 0 voltage at the fuel pump.
Old 08-16-2004, 08:04 PM
No there is 0 voltage at the fuel pump. And i do not need a new fuel pump I know for fact that the fuel pump works, just not getting power.
Old 08-16-2004, 09:29 PM
JoeWagon's Avatar
Banned
Well go back through it and figure out where it's not getting power, how is it at the fuse? If I were you, I'd just rewire the pump anyway.
