will these wheels fit?
need help. want to change the look of my 86 z28 with new wheels. will 15x10s fit or will the fronts scrub when i turn? or could i use 15x8s up front and 15x10s on back or will that look stupid? i want to use deep dish wheels because i do not like these newer wheels that are almost flush. thanks for any help or any ideas.
I would think that someplace online would have this information like American Racing or something. If not, you could call your local salesman who will be able to look in his books to tell you.
so far i can not find any thing online. just thought someone on here might have done this before. thanks
Re: will these wheels fit?
i think they would rub when your turned.... actually im pretty positive they would....
what mm offset are they???
the 15x10s are -46mm and the 15x8s are -18mm
the offset on your Z28 is 0mm front and rear.. no offset! I dont think they'l work.. You can get spacers for them, but they're expensive
And your bolt pattern should be 5 on 4.75
1991 Camaro Z28 |
it certainly wont look stupid...
*Better power-to-weight ratio than a C6 corvette* |
nailz 69 should answer if e did any changes on his 3rd gen when he put on 17"x9.5" in the front and 18"x10.5" in back
It is not the width of the wheel as much as it is the offsett
indeed...
Re: Re: will these wheels fit?
Re: Re: Re: will these wheels fit?
1991 Camaro Z28 |
If you go to a tire factory store that sells rims they can show you a list of what will fit on your car.. the camaros do not have a real wide selection like some other cars with a diff off set....
Its a real drag
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering ![]() |
