Old 08-16-2004, 03:08 PM
fs_wheel fs_wheel is offline
Question 99 GS Headlight bulb replacement
My son in NV calls last night on how to replace lo beam bulb on his Eclipse. Since I am in OK and have not worked on the car, I can only imagine that it is as simple as finding the bulb holder under the hood, twisting holder, using gloves to remove old and install new. Any secrets / things to watch out for? Thanks.
Old 08-16-2004, 03:27 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: 99 GS Headlight bulb replacement
don't get any finger oil on the bulb or it will explode if you don't clean it off.
1. pop hood
2. twist weather cover from stricken headlight
3. pop metal holdback clip open
4. pull out harness/bulb
5. replace bulb
6. put in housing
7. replace holdback clip
8. screw weather cover back on
Old 08-16-2004, 05:29 PM
Thanks - I knew it would be relatively easy.
