Old 08-16-2004, 01:05 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
ECU tech
is there anyone here that happens to know how a car's ECU is programmed. not like performance programming with a hypertech, but like what language is used? what kindof of data structures are implemented? i want to know why i have to buy a device that programs my computer, when i am perfectly capable of programming it myself...
*Better power-to-weight ratio than a C6 corvette*
Old 08-16-2004, 01:17 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: ECU tech
that is a very good question you have there man.... i was thinkin about that a while back.......
Old 08-17-2004, 02:56 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: ECU tech
I would ask the rice burners. Programming ECU's are a bigger thing with imports than domestic cars. Look on the net also. along time ao I found a place that provided software for programming the computer. Search for "desktop software ODB ODBII" or something of that nature
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 08-17-2004, 12:03 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
dont know really what language it's written in or anything. but i know the prom (programable read only memory)is programmed data tables. a program is written based on how the engine should opererate, then ecm takes incoming data and compares it to a table, then makes adjustments in pulse width, timing, etc. until the incoming data is closest to that table.
a programmer converts the information written to that prom into something you can read and adjust. check out thirdgen.org, i've seen a few tech questions on how to re-program and write scripts. i know third gens use OBDI, but OBDII is pretty much the same except the prom isn't removable.
Old 08-17-2004, 12:33 PM
Re: ECU tech
indeed, i know that there is computer software on the market that can interface with the ECU and change values in the prom and such. i was wondering cause if i can write my own code to do that than i could save tons of money...
Old 08-17-2004, 01:02 PM
4onFloor's Avatar
you can definatly write your own scripts, but learning how to do it will time some time. i'd like to learn how to do it too. i've read tons on how to un-loop, flash, write binary codes and script, but never had the time to sit down and try it.
Old 08-17-2004, 01:13 PM
Re: ECU tech
i hear that. stupid time, gotta be all, linear...
