Old 08-16-2004, 08:44 AM
fender5's Avatar
fender5 fender5 is offline
Send a message via AIM to fender5
parallel wiring
How do you wire two 4ohm subs so that the amp sees a two ohm load?
Old 08-16-2004, 09:09 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: parallel wiring
single or dual 4 ohm?
www.cloudcity.deviantart.com
Old 08-16-2004, 05:26 PM
fender5's Avatar
single
Old 08-16-2004, 05:36 PM
Haibane's Avatar
Re: parallel wiring
run both positives to the same positive on the amp, both negatives to the same negative on the amp. Or run pos on one sub to pos on other sub to amp. same with negative
Old 08-16-2004, 05:54 PM
fender5's Avatar
is that the same as bridging it
Old 08-16-2004, 06:13 PM
Haibane's Avatar
Re: parallel wiring
I never call that bridging it... and technically it is more like wiring series when you bridge I think, but w/e
Old 08-16-2004, 06:15 PM
Haibane's Avatar
Re: parallel wiring
you bridge an amp not subs
Old 08-16-2004, 07:50 PM
fender5's Avatar
so then which terminals do i hook the wires up to my amp
if it has four terminals.
Old 08-16-2004, 08:05 PM
Haibane's Avatar
Re: parallel wiring
Is it a 2 channel amp or a mono amp?
Old 08-16-2004, 08:14 PM
fender5's Avatar
2 ch
Old 08-16-2004, 08:33 PM
Haibane's Avatar
Re: parallel wiring
Run one positve to one positive on the amp, one negative to one negative on the amp. Use different positive and negatives for each sub.
Old 08-16-2004, 09:06 PM
fender5's Avatar
so does that mean that i dont use two terminals?
Old 08-16-2004, 09:13 PM
Haibane's Avatar
Re: parallel wiring
no that means you do use two terminals on the amp
Old 08-16-2004, 09:21 PM
fender5's Avatar
But does it matter that the amp is not 2 ohm stable in bridged mode?
Old 08-16-2004, 09:35 PM
cody911911's Avatar
cody911911 cody911911 is offline
Re: parallel wiring
ok. you dont want to parralel the subs the bridge the amp what haibane is saying is put each speaker on its own channel pos to pos neg to neg on one subs and amp channel and then repeat for the next sub.
1st rule of drinking and driving.......you gotta have a beer.....
