Old 08-16-2004, 12:54 AM
Pimpdady753 Pimpdady753 is offline
Angry .5 ohm amp question
ok im going to be getting this amp probbaly http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
what i need to know is all the wireing digrams say i can ether wire my duel (2ohm duel voice coil) subs at ether 2ohms or .5ohms what i am woundering is the amp is 1ohm stable so what the frick am i soppose to do. i need that 2400 the 1watts not 200 i need more power. some one plsease help me.
Old 08-16-2004, 08:40 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: .5 ohm amp question
dual 2 ohm sub will wire to 1ohm or 4 ohms. do positive to positive to positve bridged on amp. Negative to negative to negative bridged on amp.
www.cloudcity.deviantart.com
Old 08-16-2004, 12:54 PM
but i have 2 subs, i know they can wire down to 1 ohm by there selfs. but i have 2 subs
Old 08-16-2004, 01:22 PM
Haibane's Avatar
oh... I missed that part... I would get two amps IMO.
Or try the DEI mono high end amps. They can handle some abuse. That Amp you are looking at will rape your alternator
Old 08-16-2004, 01:25 PM
Haibane's Avatar
How much power do you want per sub? What subs are they? what is their RMS??
Old 08-17-2004, 11:18 AM
These are my subs, http://cgi.ebay.com/ws/eBayISAPI.dll...1&ssPageName=W
They say there rms is 2000 so i would like to put about if not more then 2000 rms in to each. that is why i need that 1ohm on the amp.
Old 08-17-2004, 11:45 AM
Abell255's Avatar
Abell255 Abell255 is offline
Send a message via AIM to Abell255
Jesus, so your amp needs to put out 4,000 watts RMS...
Old 08-17-2004, 11:59 AM
Haibane's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW there is 1.
Here is the next http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Get 2 amps
Old 08-17-2004, 12:06 PM
TFFantasy44 TFFantasy44 is offline
Just about anything he hooks up is gonna rape his alternator...
Old 08-17-2004, 12:53 PM
Haibane's Avatar
not as bad as that amp. it is a high current class A/b amplifier... Class Ds are much nicer to the alternator
Old 08-17-2004, 09:22 PM
so those amps are better then the AUDIOBAHN amp. I would have like to go all AUDIOBAHN, but if those amps are better, Then i might go with your amps any other recomendations on amps, Any ones that look cool. Thanks
Old 08-17-2004, 09:29 PM
doesnt the AUDIOBAHN amp have 2 channels, So cant i just run one sub on one channel and the other sub on the other, and wire them down to 1 ohm,
Old 08-17-2004, 09:36 PM
Haibane's Avatar
you can get two audiobahn 1800t class d's( I think that is the model)
Running them 2 channel at 1 ohm each channel is the same as running them 2 channel bridged at .5ohm
Old 08-17-2004, 09:37 PM
Haibane's Avatar
A18001DT get 2 of them
Old 08-18-2004, 01:53 PM
Those things are fricken expensive, i cant afford that much money, can you recomend and other amps the most i can spend is 500 dollers on ether one amp or on 2 amps, so the 2 amps have to be around 250 each. Thanks
