Old 08-15-2004, 11:10 PM
Stroked it Stroked it is offline
Rocker Sizes (350cid)
I will (in the near future) be building a 350. I need to know what rocker ratio i need to get, the 1.5 or the 1.6. The cam im putting in will have 260º/272º duration if that helps,,, and .427''/.454'' Gross lift. I'm kinda new at this and as you can tell i need help,,,, peace
Black 79' Monte Carlo
Built 350
TH-400 trans.
3.73 limited rear end
Edelbrock IAS Shocks
14" Cragar Keystone Klassics
60 wide BFGoodrich Radial T/A
Not too bad for $1500
Old 08-15-2004, 11:53 PM
mike123 mike123 is offline
Re: Rocker Sizes (350cid)
doesnt 1.6 add like .010 or .020 lift?
Old 08-16-2004, 12:53 AM
68chevelle 68chevelle is offline
Send a message via AIM to 68chevelle
usualy, unless spacificaly stated, the cam lift is advertised with 1.5 ratio rockers being asumed. if you want to know what the actualy lift on the cam itself is, you would take the .427 and devide by 1.5 and thats what the cam actauly lifs, and then if youw ant to figure out the life with 1.6 rockers, you would multiply that number,(the actaul cam lift), by 1.6. stock ratio is 1.5, i would say thats probably what you want to go with. 1.6 rockers usualy require other modifications to be done, for the most part. atleast it is recomended, but not always mandatory. things like tall valve covers, screw in studs, just stuff like that, plus you need to make sure your springs can hadle it too, just a buch of other stuff like that.
<<my engine
<<part of the front end during engine swap
other pictures of my car... click here
Old 08-16-2004, 12:22 PM
Thanks,,,, that helps alot
Built 350
TH-400 trans.
Old 08-16-2004, 11:01 PM
Deadcarny Deadcarny is offline
order a custom gound cam with the specs you want and try the 1.5 rockers. the more rocker you get, the more stress on the valvetrain.
1995 Camaro Z28, 383ci 485+hp 495ft-lbs SOLD!!!
1965 Ford F100
1967 Chevrolet Impala (Sold)
1972 Chevrolet Chevelle (Sold)
1972 BMW R60/5 (Sold)
1980 Harley Davidson FLH
1987 Harley Davidson XLH
1992 Astro EXT AWD
1992 Chevrolet Cavalier
2000 Monte Carlo SS Pace Car 1087/3222 (Sold)
2001 Pontiac Sunfire
2002 Trailblazer LTZ (Sold)
South Carolina F and Y Bodies
www.SCFYB.com
Old 08-16-2004, 11:11 PM
Dober89 Dober89 is offline
i say email summit racing they know their shiznit
Old 08-17-2004, 08:48 AM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
indeed...
*Better power-to-weight ratio than a C6 corvette*
