Old 08-15-2004, 10:40 PM
sinaloa67chevy sinaloa67chevy is offline
electrical short
i think i may have a short when i unplug my negative battery wire and connect a volt meter from the neg. battery terminal to the neg. battery cable i ge a votage reading of 4-6 volts only if radio battery wire is connected or i i turn on the headlight switch. whats the best way to find a short? please help
Old 08-16-2004, 08:35 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: electrical short
have someone inthe cab pull each fuse until the draw goes away. That will point you to roughly what it is that has a short. I had to do it to my work van not to long ago. Of course it doesn't help that my van has a VHF two way, a 800Mhz two way, and strobe lights on it.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 08-18-2004, 01:12 AM
TweakedGM TweakedGM is offline
shut everything down ,radio ,door shut, headlights off, if you have a hood light take the bulb out. then disconnect the neg then put a test light to the battery and clip the other end to the neg if you have a light you have a draw. you said something about your radio pull the fuse on it if the light goes out. put your radio on an acc. power so when you turn the key on the radio is on.
Old 08-25-2004, 11:13 PM
I get a draw only with the radio witch does have a memory, if i turn on my headlight switch and even igntion switch. igntion switch is new, radio is also.
Old 08-26-2004, 03:17 AM
how do you have the radio hooked up. and what type of radio.
Old 08-26-2004, 03:57 AM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Ever asked yourself what's this wire for?????? or where does this wire go???????? If so, theres your problem!! Sorry I can't be of more help
Old 08-29-2004, 03:15 PM
I hav e the radio hooked up to turn on with my ignition switch on it does have a wire that goes to dirrect current for the memory. I have it ground to the body.I get the draw with the ignition switch off
