Old 08-15-2004, 07:08 PM
szterrell szterrell is offline
1999 Astro Van starting problem
My 1999 Astro van doesn't start 7 out of 10 time ... no crank no noise no nothing. Sometimes if I put it in neutral - it'll start. Sometimes if I open the hood and let it cool off for 15 minutes - it'll start. Sometimes if I take the square ignition starter fuse box under the hood out and put it in cool water then reinstall - it'll start. I have had a new starter installed along with transmission selector switch to the tune of over $500 and the problem still isn't fixed! Can any body help?!! Thanks, Suzi
Old 08-16-2004, 04:47 PM
tysons tysons is offline
Re: 1999 Astro Van starting problem
engine ground good?
Old 08-17-2004, 09:10 AM
KathyD KathyD is offline
Related 99 Astro staring problem?
I'm not sure if this is related to your problem, but my 99 Astro has an intermittant starting problem as well. It seems only to happen when it's raining or VERY humid out. It turns over, but won't start. Father-in-law who knows about cars bypassed the passkey system (as if he were going to install a remote starter) since there seems to be trouble with the passkey system in these things, but that didn't seem to help. Sometimes, if I leave the key on for 10 minutes (apparently the time it takes the system to reset) it will start and run fine, other times it takes waiting 10 minutes twice, other times this doesn't work at all! Would love some advice as well, since I'm not sure where to start...I don't want to spend a fortune fixing things that won't solve the problem.
Thanks!
KathyD
Old 08-19-2004, 06:00 AM
kathy have you ever had a tune up on your truck?
sounds like bad wires.
Old 08-22-2004, 01:59 PM
RDOW RDOW is offline
Re: Related 99 Astro staring problem?
Thanks!
KathyD
I have the same problem with my 97, It does not want to start when it rains, I have replaced the fuel pump but the problem is still there. any luck please let me know.
Old 08-22-2004, 04:18 PM
LTJGWorth's Avatar
LTJGWorth LTJGWorth is offline
Check out http://www.astrosafari.com for an answer. That place is great.
Old 12-21-2004, 09:11 PM
dimotorsports dimotorsports is offline
For the guys with the hard to start after rain...
Sounds like a bad coil pak...
Moisture will cause them to be faulty.
Byron Smith
www.DistinctiveImageStreetwear.com
Old 12-22-2004, 07:43 PM
JFL JFL is offline
Had an intermitent starting problem on my 99 about 1 1/2 yrs ago. Mecnanic said it was problem with passkey system, worn contacts in ignition switch. Replaced switch and everything was fine for about 14 months then problem started again. This time mechanic replaced ignition module and problem went away (fingures crossed).
Old 05-13-2006, 01:29 PM
clancy95 clancy95 is offline
did you fig out how to stop this problem i have the same problem its a pain in the ,,,,,,,.
Old 05-13-2006, 01:47 PM
strunch strunch is offline
I have the same year van and the exact same problem with it not starting when it rains. Still looking for solution.
Old 05-14-2006, 10:44 PM
GCSCanada GCSCanada is offline
I had same problem with my van only starting some of the time. It was the passkey system. Replaced the ignition switch. All was then great.
For KathyD (not starting in the rain)- had the same problem with not starting (or continuing to run in my case) when it was humid or raining. The coil was the problem. The first coil I installed (new from dealer) was bad. Cracked just like the old one I replaced (boy was I happy when it died again the next day it rained!). Got it replaced, all works great now. I checked the coil by starting my van at night and spraying water at the coil using a plant mister. It lit up like a Christmas tree where it was crecked. Replaced it, with a good one, and all has been fine since.
