96 ply voyager 2.4 cylinder replaced coil pack, crankshaft sensor,still no fire engine won't start. it will turn over but won't start.help!!!!!!!!!!!!!!!!
Timing Belt?
Have You Checked the Timing Belt? (Maybe Broken)
If the Teeth on the Belt have worn off, the engine will still turn over. |
Re: no fire to the coil van wont start
Have you checked MAP Sensor? I think you can disconnect vacuum hose to it & start if it's bad.
Have you checked Automatic Shutdown Relay? |
Is the Check Engine Light on? What codes are stored? Is the engine getting spark? Is it getting fuel? On the 2.4L, it is very easy to pull off the top timing belt cover to see if the cams are turning.
