Old 08-15-2004, 06:42 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
best Spark Plugs...
I want to replace the plugs and wires on my 95 Dodge Grand Caravan 3.3L V6 and would like to know which are the best all around best spark plugs and wires for the money. I'm not looking for anything fancy or expensive (it's not a race car!), but at the same time I don't want any cheap parts that would replacement prematurely.
Something like GM plugs, I know they're the best bang for the buck for GM vehicles, but I don't know what works best for Chrysler vehicles. Any help anyone could offer will be greatly appreciated. Thank You!
Old 08-16-2004, 11:16 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: best Spark Plugs...
I personally like Bosch Platinum plugs. The cost about $2 each but hold up well even in performance engines. As far as wires there are many good manufacturers of wires out there. It is best to get a set that matches OEM quality as many of the other wires may cause problems. Since it is not a race car standard size wires should work very well for your application. Bosch also makes wires to go along with the plugs!
Old 08-16-2004, 01:23 PM
Ed_Strong's Avatar
Son of a Mechanic
A lot of people have also recomended the Bosch Platinum plugs and wires, I think I'm gonna go with those...
Thanks for helping!
Old 08-19-2004, 05:50 AM
Ed_Strong's Avatar
Son of a Mechanic
Is it hard to change the plugs? Any tips from the Pros?
Old 08-19-2004, 06:23 PM
Pontiac Guy
It is not hard to change the front three plugs but the three in the rear are another story. The change the front three plugs simply remove the wire, remove and reinstall the plug and seat the wire on the plug. For the ones in the rear there is only one easy way to get to them and that is to remove the phlenum. Of course you need to remove the coil pack and the throttle body. You can get to them from underneath if you have a lift but it is still quite difficult. I bought the plugs and wires and had a shop change the rear plugs for me. Still cost me $60 but he scanned the computer too. Hope this helps!
Old 08-20-2004, 10:56 PM
Ed_Strong's Avatar
Son of a Mechanic
UPDATE:
I got the BOSCH Platinum Plugs, Wires and Oxigen Sensor installed and the van and now it runs, responds and behaves so much better now. I had the Air & Fuel Filters, PCV & Air Breather replaced last week. With this full tune up I have to see if I can also get good gas mileage on it too!
Old 08-21-2004, 05:45 PM
Pontiac Guy
Sounds like you did it right. You should see a difference in the mileage almost immediately. Good Luck!
Old 08-21-2004, 11:21 PM
Ed_Strong's Avatar
Son of a Mechanic
Well I'll be on my way down from New Jersey to south Florida by next week, so we'll see how it goes...
